directed 564t
Old May 24, 2008 | 04:56 AM
dragonjay006's Avatar
Default directed 564t
ok so i just in stalled this alarm into my 96 civic hb my first alarm install went well but neways, i think i forgot to conect a wire to the ignition cause if the alarm is triggerd then disarmd and i start the car the led continuse to flash for the whole ride, it seems as if the alarm isnt reseting itself when i turn the car on, so my question is what wire didnt i conect and im not using the remote start feature.
thanks for the help
Old May 24, 2008 | 06:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: directed 564t (dragonjay006)
That would be the Hornet 564T, you will need to connect the yellow lead, in the ribbon harness that runs from the main unit to the remote start relay satellite, to a "true ign." source, you can remove, [depin] all the other leads in the ribbon harness leaving only the yellow one.
Another thing that may work is repining an unused lead in the main harness, [H1] like H1/7 violet, [pos.(+) door trigger] to pin H1/9, [what would be the ign. input if it was just an alarm] this only works on some DEI alarm/remote start combo units, the yellow lead in the ribbon harness works on all of them. 94
Manny C
Audio / Security / Video
Mar 17, 2014 08:42 AM
Axatax
10
Apr 8, 2012 11:22 AM
thelonerangers
Jul 7, 2006 02:54 PM
TurboBumblBee
Oct 14, 2002 08:47 AM
