Initial start up problems! clacking sound and engine wont rev up!
Old Mar 8, 2008 | 09:56 AM
P12 EG6's Avatar
Default Initial start up problems! clacking sound and engine wont rev up!
as the title says i just did the initial start up of my new engine. idles fairly well but has a "clacking"noise reminds me of a rod knock ? I let it idle for a little bit and i tried to give it a little gas. it wont rev ?. I adjusted the valves and double checked the timing. everything is fine. so now im stumped is it the brand new built block or piston/valve contact? any input would be appreciated! thanx
Old Mar 8, 2008 | 12:02 PM
GhostAccord's Avatar
Default Re: Initial start up problems! clacking sound and engine wont rev up! (P12 EG6)
Did you measure everything for proper clearances during the build and before you started the engine? The person who checked the clearances and built the engine would be the person to ask about piston to valve clearance problems.
A little info about the build the parts that you put into it and what your using for engine management would also be helpful.
Brembomaster
May 26, 2019 07:51 PM
captain_sl0w
Jul 20, 2008 05:42 PM
Kongo69
Honda Civic (2001 - 2005)
Jul 14, 2008 01:27 PM
Shinbo
Nov 7, 2004 11:16 AM
RABBIT9
Apr 22, 2003 02:13 PM
