will LS axies fit GSR tranny?
Old Mar 8, 2008 | 05:26 AM
jdmlseg6's Avatar
Default will LS axies fit GSR tranny?
i just got a GSR tranny for my EG6 with a LS in it and i was worunding if the LS axies fit the GSR tranny just want to now if i have to buy GSR axies
Old Mar 8, 2008 | 05:28 AM
SirRevvs's Avatar
Default Re: will LS axies fit GSR tranny? (jdmlseg6)
same ****.
Old Mar 8, 2008 | 05:36 AM
Dasfinc's Avatar
Default Re: will LS axies fit GSR tranny? (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">same ****.</TD></TR></TABLE>
yea, IIRC all B-series axles are the same *Even automatic axles as thats what I'm using in my LS swap*
Old Mar 8, 2008 | 05:40 AM
SirRevvs's Avatar
Default Re: will LS axies fit GSR tranny? (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc &raquo;</TD></TR><TR><TD CLASS="quote">
yea, IIRC all B-series axles are the same *Even automatic axles as thats what I'm using in my LS swap*</TD></TR></TABLE>
Except 90-93 driver side da axle is different from 94+ b series axle. Just reuse your old int. shaft and axles you'll be fine.
Old Mar 8, 2008 | 05:43 AM
Dasfinc's Avatar
Except 90-93 driver side da axle is different from 94+ b series axle. Just reuse your old int. shaft and axles you'll be fine.</TD></TR></TABLE>
Forgot about that, thats the axle you use in a EF for a b-series swap right?
Old Mar 8, 2008 | 05:45 AM
crazyguy's Avatar
yes it will but da integra wont.
Old Mar 8, 2008 | 05:49 AM
SirRevvs's Avatar
Forgot about that, thats the axle you use in a EF for a b-series swap right?</TD></TR></TABLE>
they work in all civics and integra's you just have to have a da int shaft and change out the driver side axle seal to a da axle seal. Lengths are almost identical. But yeah alot of people use them in ef swaps because they usually use OBD0 engines and trannies that come with the da style int shaft.
Old Mar 8, 2008 | 05:51 AM
SirRevvs's Avatar
DA int shafts suck ***** though, ever had an axle that wouln't come out of that damn hole? Sometimes its permanently in there. Hence why honda switched to the dc style int shaft.
Old Mar 8, 2008 | 07:50 AM
.PLUMMM's Avatar
Yep. Make sure it clicks in before you lower the car and drive though! My friends popped out because he "thought" it was in lol
Got Snail 2
Jun 26, 2007 09:27 PM
EK_Rider253
Feb 9, 2007 09:45 PM
superstreetb16
Jul 31, 2005 04:26 PM
Chuji
Jun 30, 2004 06:54 PM
slowem1si
Feb 26, 2004 05:15 PM
