b16a SiR and b16A2 EM1 question?? not the normal
I have a b16a obd0 from a SiR, and I have a b16A2 in my EM1, I want to have a built engine so I can boost it but I can't have the down time associated with the build. So I was thinking about just building the obd0 bottom end and then swapping it with the obd2 bottom end, and using the head from the EM1. Is this a bolt on swap or will it need modifying and if so what needs to be done? Basiclly will a obd0 bottom end fit on a obd2 head? PIcs because people like pics!
there are slight differences in the blocks...but the most part you'll be fine....make sure to use obd2 oil pump on the non obd engine and the water tube and oil cooler from em1.
chad
chad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizzoTK »</TD></TR><TR><TD CLASS="quote">on the oil pump.</TD></TR></TABLE>
AAHHHH, that makes sense!
Stylinhonda
54
Sep 16, 2005 05:06 PM
