Wiring up 3 - 4 ohm svc subs.
Old Mar 7, 2008 | 10:42 AM
Matthew_zero's Avatar
Default Wiring up 3 - 4 ohm svc subs.
Ok, my amp is:
400 watts x 2 at 2 ohms,
200 watts x2 at 4 ohms,
800 watts x1 at 4 ohms.
and i have 3 - 4 ohm subs. 250 rms.
Can i wire each chanel differently?
1 chanel wired to one sub at 200 watts @ 4 ohms,
1 chanel wired to two subs at 400 watts @ 2 ohms (2 in parallel)
Old Mar 7, 2008 | 11:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: Wiring up 3 - 4 ohm svc subs. (Matthew_zero)
You can, but it will sound like crap, you have the wrong amp for the subs, [or the wrong subs for the amp] find a mono block sub amp that is at least 1x800W RMS into 1 ohm, is 1 ohm stable, wire the subs in parallel for a 1.333 ohm final load. 94
Chi
Audio / Security / Video
Mar 7, 2007 10:09 AM
Mazzazx51
May 19, 2004 05:55 AM
GroundZer0 336
20
Aug 30, 2003 04:27 AM
redteg1
Apr 9, 2002 08:45 PM
vtec-outlaw
Feb 4, 2002 12:45 PM
