Help with Wiring On a Sub
Old Mar 5, 2007 | 07:25 AM
Chi's Avatar
Chi
Default Help with Wiring On a Sub
Hello, I have an Infinity Perfect 12.1 that recommends 350 Watts RMS Dual 4OHM VC
I'm using an old Fosgate 750s which puts out
187.5 Watts *2 Channels 4OHM
375 Watts * 2 Channels 2OHM
and 750 Watts * 1 Channel bridged 4OHM
How should I wire the sub to the amp? The bridged 4OHM looks best of course but I don't want to blow my darn sub. Any recommendations?
Old Mar 5, 2007 | 12:30 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Help with Wiring On a Sub (Chi)
Well since you have a dvc 4 ohm sub I would reccommend that you get anthor amp. Your sub can be wired at a 8 ohm load or a 2 ohm load. At 8 ohm you will underpower the sub. And at 2 ohm you will be way over powering the sub. Even with the gain turned all the way down at 2 ohm I would watch the speaker for any signs of being over powered. You need to run both voice coil of the sub. There are many debates on this. But I allways play by the rules. If the manufactor says both vc use them. Go with the 2 ohm load and be very carefull on the gains. I say just to look for a new amp or add one more sub to your system. Or wire the sub to a 2ohm load and rock it stereo instead of bridge.
Old Mar 5, 2007 | 01:45 PM
Chi's Avatar
Chi
Default Re: Help with Wiring On a Sub (wrx-killer-Sti eater)
Thanks wrx-killer-Sti eater
With a 4 OHM bridged mode the amp will put out 750 into that channel, if I run the sub in series with an 8OHM load would that theoretically knock that power down to 375?
Old Mar 6, 2007 | 04:32 AM
FullRaceHonda's Avatar
yes wirering it at 8 ohms will theoreticaly give you about 400 watts to the sub, and it also gives youthe flexibility to pick up another sub if you want to later
just make sure you wire it right and bridge the amp right, do you know how to wire the sub in series?
Old Mar 7, 2007 | 09:02 AM
Chi's Avatar
Chi
Default Re: Help with Wiring On a Sub (FullRaceHonda)
Yes thanks FullRace, I believe positive on one vc and the negative on the other to the amp and then short the other halves together
Old Mar 7, 2007 | 10:09 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chi &raquo;</TD></TR><TR><TD CLASS="quote">Yes thanks FullRace, I believe positive on one vc and the negative on the other to the amp and then short the other halves together</TD></TR></TABLE> That is correct, run it at 8 ohms, your amp is not stable below 2 ohms when bridged, it will just over-heat.
There are advantages running at 8 ohms, you will also have about 1x375W RMS into 8 ohms, perfect. 94
Matthew_zero
Audio / Security / Video
Mar 7, 2008 11:07 AM
Mazzazx51
May 19, 2004 05:55 AM
GroundZer0 336
20
Aug 30, 2003 04:27 AM
JTCdudeman
10
Jan 20, 2003 09:40 PM
vtec-outlaw
Feb 4, 2002 12:45 PM
