turbo time? for civic ex
hey im just starting out and was wondering a good turbo kit for a d16y8
i was reading somewhere that the edelbrock is more complete bolt-on.
if you buy any turbo KIT for you d16y8 its going to be bolt-on - full race makes a really good kit...but its on the expensive side..il give ya a couple links
http://www.tunerheadquarters.c...17_18
http://www.full-race.com/catal...01284
good luck and welcome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:si:. »</TD></TR><TR><TD CLASS="quote">dont waste your time go bseries.</TD></TR></TABLE>
lame response - he clearly stated "turbo time"...not "b series swap time"
i have a b series, dont waste your time, put about 1000, buck into buildin the motor then piece togeather a kitand it will be cheaper and faster then a b series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 »</TD></TR><TR><TD CLASS="quote">
exactly, just upgrade the valve train..get a decent turbo kit (unless you can afford the ones in the links i posted) and you'll be set
</TD></TR></TABLE>exactly, just upgrade the valve train..get a decent turbo kit (unless you can afford the ones in the links i posted) and you'll be set
check the good ole marketplace for forced induction. you can find all you need to boost everything from your d-series to your lawn mower lol
but go to the forced induction thread and read up on everything you need before you go out and just start buying random *** junk
EL'ation
Apr 14, 2003 09:41 AM
