Cleaning headlight plugs?...
Old Mar 6, 2008 | 11:18 AM
VTECth1s's Avatar
Default Cleaning headlight plugs?...
When replacing my head light bulb on my 00 civic. I noticed a lot of gunk build up on the headlight plug itself. And once I put on the replacement bulbs. The driver side headlight wont turn on. The passenger side works fine, the gunk is like brown almost like peanut butter consistency.
Anything I can do to clean it, cause I think it's preventing electrical connection to the bulb. But it will turn on when I use the high beam. I made sure the replacement bulb was fine because I switched it to the passenger side and both work. Any ideas?
Old Mar 6, 2008 | 11:21 AM
ferio252's Avatar
Default Re: Cleaning headlight plugs?... (VTECth1s)
just to be safe, i would use a rag soaked in some soapy warm water.
Old Mar 6, 2008 | 11:44 AM
VTECth1s's Avatar
Default Re: Cleaning headlight plugs?... (ferio252)
It's inside the plugs, not on the outside.
Old Mar 6, 2008 | 01:13 PM
2tonecivic21's Avatar
I would use something like NoFlash. It is an electro contact cleaner. Something to that nature.
Old Mar 6, 2008 | 03:23 PM
VTECth1s's Avatar
Default Re: Cleaning headlight plugs?... (2tonecivic21)
I just got some eletrical cleaner, still didn't help. The low beam still doesnt turn on, and bulbs are brand new.
Old Mar 6, 2008 | 06:10 PM
CHI-D16's Avatar
dam i got the same exact problem with my eg
it only works in high beam
Old Mar 6, 2008 | 06:50 PM
prplhrtcivic's Avatar
Sometimes with all that build up, once the old light is taken out, you break what's referred to as the "super-secret mechano-electro-chemical bond," and the plug will never work again. Seriously, what I'd do (unless it's a fuse) is probably just pull one from the junk yard and splice it in.
Old Mar 6, 2008 | 09:01 PM
VTECth1s's Avatar
Default Re: Cleaning headlight plugs?... (prplhrtcivic)
I think thats what happened, cause even the new bulbs I got don't work. Damn!
How bad is it to run off high beams? The bulbs could eventually burn out right?
Old Mar 7, 2008 | 10:05 AM
CHI-D16's Avatar
im gonna clean the gunk out the plug wire and see if that works cuz only the driver side is dirty and only the driver side doesnt work
Old Mar 8, 2008 | 07:57 AM
VTECth1s's Avatar
Default Re: Cleaning headlight plugs?... (CHI-D16)
bump!...if anyone has a solution
Old Mar 8, 2008 | 11:02 AM
VTECth1s's Avatar
problem has been fixed!!..
I checked the low beam fuses under the dash. And wow they both were blown. I replaced them and now its working again!
Old Mar 8, 2008 | 11:29 AM
jers99's Avatar
Well I'd still like to know cuz mine does the same thing and I gotta get out and tap the headlight everyday for it to turn on. Its all brown as well. I check the wires and none seemed to be loose and fuses are ok
Old Mar 8, 2008 | 11:30 AM
Eran's Avatar
HT White Ops
This brown buildup is probably a mixture of dust and degraded dielectric grease.
Use some CRC QD Electronic Cleaner and a shop rag to clean the plugs.
Old Mar 8, 2008 | 12:32 PM
VTECth1s's Avatar
Default Re: (Eran)
I already did that too, looks a lot better. But the low beams work now since, I replaced the fuses cause they blew.
gold_ef
Oct 20, 2006 02:43 PM
Senbonzakura
Jan 4, 2005 07:48 PM
Mark Murda
Sep 17, 2004 11:55 AM
defaced
Apr 8, 2004 08:22 PM
integra99blue
Jan 15, 2002 06:39 AM
