Rear brake caliper piston removal.
Old Mar 6, 2008 | 10:52 AM
sk8shorty012's Avatar
Default Rear brake caliper piston removal.
So i'm attempting to re-build a set of rear ITR brake calipers. I've taken the caliper off (obviously) and now im trying to get the piston out. I've used a long flat head to twist the assembly most of the way out. It's about 1" from the pad clamps, so it's almost there. Now heres the problem, it just keeps twisting, but not coming up or out any further, and it'll get kind of stuck at one point on each revolution. Am I missing something / is there a special trick at this point?
Old Mar 6, 2008 | 11:22 AM
1992Si's Avatar
That's why you just buy a rebuilt caliper.
Much easier
Old Mar 6, 2008 | 11:27 AM
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">That's why you just buy a rebuilt caliper.
Much easier</TD></TR></TABLE>
Too bad they're very expensive, especially considering that its an ITR rear caliper. I'd much rather spend the $15 for the seal kit and spend time rebuilding it rather than money.
Old Mar 6, 2008 | 11:28 AM
nub's Avatar
nub
Default Re: Rear brake caliper piston removal. (sk8shorty012)
once youve rotated the piston all the way out you need to blow the piston out of the caliper with compressed air just like the fronts if you were to rebuild them
Old Mar 6, 2008 | 11:33 AM
Default Re: Rear brake caliper piston removal. (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">once youve rotated the piston all the way out you need to blow the piston out of the caliper with compressed air just like the fronts if you were to rebuild them</TD></TR></TABLE>
right and thats what I was attempting, but I cant find a good way to get sealed air into the caliper. The fitting on the air line doesn't seal, letting air back out and not putting enough pressure on the piston. So, which fitting do I need or...?
Old Mar 6, 2008 | 11:59 AM
alright, I got it out. It was already off the thread on the inner part, just had to knock it loose from the seal with a long flathead. Now my next question is, it's filly as **** inside there, what's safe to use to clean in there?
Old Mar 6, 2008 | 12:06 PM
nub's Avatar
nub
Default Re: (sk8shorty012)
brake parts cleaner and a rag
Old Mar 6, 2008 | 02:17 PM
thanks. Do you recommend getting a new piston?
Tim2179
Jul 24, 2019 12:12 PM
BB4lude
Feb 11, 2008 01:47 PM
_jester_
14
Nov 26, 2003 04:55 AM
crxcess
Oct 9, 2002 10:50 AM
D
Aug 6, 2001 06:21 AM
