injector wires??
Old Mar 5, 2008 | 09:15 PM
95JDM's Avatar
Default injector wires??
Is there any diagrams out there to show how to match the correct clip to its injector for the stock si injectors??
Old Mar 5, 2008 | 09:20 PM
SirRevvs's Avatar
Default Re: injector wires?? (95JDM)
they should only be able to go on one way if its a stock harness, otherwise check any other honda and just go by the wire colors from cyl 1 to cyl 4.
Old Mar 6, 2008 | 10:57 AM
95JDM's Avatar
Default Re: injector wires?? (SirRevvs)
yah thats wat i need i was hoping there was some kind of digram with the colors on it but ill do it that way anyway
Old Mar 6, 2008 | 11:17 AM
nub's Avatar
nub
unless the harness has been cut open from its tape and loom it should be self explanitory wich plug goes to wich injector. with the harness on the engine the section that goes on the intake mani. by the injectors the plugs on the harness should be in the same order as the injectors. the plug closest to the driver side is injector #1,next in line is #2, next is #3, leaving #4, closest to the pass. side. #1 brn/yel-blk #2 rd/yel-blk #3 blu/yel-blk #4 yel/yel-blk
Old Mar 7, 2008 | 12:52 PM
95JDM's Avatar
Default Re: injector wires?? (nub)
nvm i figure it out there was two that where mixed up thanks
89ED
Jan 22, 2017 09:52 AM
GSR_hatch936
Sep 12, 2009 06:32 PM
adam meyer
Nov 3, 2003 09:53 PM
