POOR MAN TYPE RR!!!!HELP
Old Mar 5, 2008 | 07:11 PM
b16motor's Avatar
Default POOR MAN TYPE RR!!!!HELP
whats up guys.
Im putting my b16 PR3-4 head the head has been ported and polished and has ferrea aftermarket valves and springs with typeR Roket arms and stage2 skunk2 cams.
GSR refreshed block honed with new rings. i already have skunk2 intake maniful,aem camgears, b16b crank pulley,aem fuel rail, fuel regulator and a p28 chipped on crome.
Can i still use my b16 head bolts?? and is there anything i need to consider on doing like for example tuning or stuff like that?? or other little things?
let me know if im explaining my self right or not.thanks
Old Mar 5, 2008 | 07:17 PM
cimo463's Avatar
Default Re: POOR MAN TYPE RR!!!!HELP (b16motor)
ARP Headstuds ftw
Old Mar 6, 2008 | 06:12 AM
b18c5 EG's Avatar
no you cant i am doing a similar build and got b18 Head Studs..somebody correct me if im wrong??....get ARP to protect it!! for your other questions tuning is a must if you dont want to blow up your motor and make sure you get a gsr timing belt
Modified by 1SloSol at 10:38 AM 3/6/2008
Old Mar 6, 2008 | 06:34 AM
1988_96hb's Avatar
Default Re: (1SloSol)
im doing the same build and another member n here told me you use the gsr headstuds and dowel pins
Old Mar 6, 2008 | 06:45 AM
redvtec00's Avatar
Default Re: (1988_96hb)
I'm pretty sure you can use B16 or GSR, but while its apart I would just upgrade to ARP's. Check the FAQ section there is a thread in there on LS/VTEC builds
Old Mar 6, 2008 | 06:48 AM
crazyguy's Avatar
Default Re: POOR MAN TYPE RR!!!!HELP (cimo463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cimo463 &raquo;</TD></TR><TR><TD CLASS="quote">ARP Headstuds ftw </TD></TR></TABLE>
+1.
Old Mar 6, 2008 | 06:03 PM
b16motor's Avatar
Default Re: POOR MAN TYPE RR!!!!HELP (crazyguy)
awesome!!!!thanks
Old Mar 6, 2008 | 09:32 PM
1988_96hb's Avatar
Default Re: (redvtec00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redvtec00 &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure you can use B16 or GSR, but while its apart I would just upgrade to ARP's. Check the FAQ section there is a thread in there on LS/VTEC builds</TD></TR></TABLE>
this isnt an ls/vtec
Old Mar 7, 2008 | 11:54 AM
redvtec00's Avatar
My bad..I should have read a little more
Old Mar 7, 2008 | 12:14 PM
SkoundrelUSA's Avatar
cute little bastard
90% positive you use GSRs. I used AEBS GSRs in mine.
DagoAcura92
Jun 25, 2013 01:44 PM
b20vteclsintegra
Jul 6, 2011 10:07 AM
-HONDA-
Oct 6, 2007 09:53 AM
Drew17th
Oct 11, 2006 10:18 AM
