CTR INTAKE camshaft with Stock EXHAUST B16 camshaft ?????
Old Mar 5, 2008 | 06:41 PM
94EJ1Coupe's Avatar
Default CTR INTAKE camshaft with Stock EXHAUST B16 camshaft ?????
Wanted to know if anyone has instaled the Intake Camshaft ONLY on any B16a second Gen ext.... Any good or will I need to get the Exhaust Cameshaft as well ? I need some advise ?
Old Mar 5, 2008 | 06:51 PM
crazyguy's Avatar
Default Re: CTR INTAKE camshaft with Stock EXHAUST B16 camshaft ????? (dj Just Right)
a few buddies of mine are acutally running the ctr intake cam only with stock b16a exhaust cam. the result is pretty good. u can feel the car is pulling harder at high rpm. if u are using stock b16a springs and retainers. dont reve it over 8000 rpm. ctr exhaust cam is similar to regular b16a exhaust cam. intake cam is the one that makes difference.
Old Mar 5, 2008 | 07:47 PM
Frickr's Avatar
Default Re: CTR INTAKE camshaft with Stock EXHAUST B16 camshaft ????? (crazyguy)
the ctr exhaust cam is bigger. (more duration more lift) although the intake will wake your motor up, you will notice some more up top and more rev's if you do a whole ctr valve train
Old Mar 5, 2008 | 08:05 PM
EKstacy's Avatar
Default Re: CTR INTAKE camshaft with Stock EXHAUST B16 camshaft ????? (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">the ctr exhaust cam is bigger. (more duration more lift) although the intake will wake your motor up, you will notice some more up top and more rev's if you do a whole ctr valve train</TD></TR></TABLE>
x2....IMO, more air should = more exhaust.
ctr intake cam + stock exhaust cam is better than stock on both, but if you are taking in more air it would be better to be able to push more air out too. So if you could, i would install ctr exhaust cam too. But thats just my 2 cents. Good Luck
Old Mar 5, 2008 | 08:41 PM
94EJ1Coupe's Avatar
Good point EKstacy!!!
Old Mar 5, 2008 | 08:48 PM
SirRevvs's Avatar
Default Re: (dj Just Right)
sir 2 exhaust cam is preferred by many over the ctr. I believe it has a longer duration on the exhaust valve. I had a sir 2 engine with stock exhaust cam and ctr intake cam and it was the most pissed off b16a i've ever owned. Made 360 whp with a ebay turbo kit, proffessionally tuned of course, on 18 lbs.
ketchup!'s Avatar
does installing a ctr cam in a b16 require tuning?
Old Mar 5, 2008 | 08:50 PM
SirRevvs's Avatar
Default Re: (ketchup!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ketchup! &raquo;</TD></TR><TR><TD CLASS="quote">does installing a ctr cam in a b16 require tuning?</TD></TR></TABLE>
No stock ecu works just fine, only thing required is a valve lash adjustment.
Shartek
Jun 28, 2008 03:38 PM
daigo
Apr 4, 2005 08:38 PM
DC2*Integra
May 13, 2004 06:25 PM
Weslay
Mar 4, 2002 10:16 AM
