BIG!!!!!! headlight problem
I have a 1995 integra and one day my low beam light was flickering on and off. Then a couple days later it just stopped working. Then a couple days later the other side low beam stopped working. So i tried fixing it and it ended up losing another light my left high beam. So know i had both low beams that dont work and my left high beam not working. I know its not the bulbs bc i checked them. I also checked the wire with a test light and no power in any of the three. So hopefully someone can tell me what to do to get it to work because it is really annoying......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Check the grounds and verify 12V at the harness. If 12V is not present, check the switch, etc.</TD></TR></TABLE>
Switch is fine, nd i doubt thatd be it cuz only 3 out of four lights lost power....no power at tha Bulb harness, or where on tha harness are you referin to??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 »</TD></TR><TR><TD CLASS="quote">please tell me you checked the fuses.</TD></TR></TABLE>
tha fuses were tha first thing checked, nd checked every time i've tryed figureing this problem out
Jacen
Mar 22, 2006 10:51 PM
