y7/y8 w/ skunk2 cam gear timing problem
Old Mar 3, 2008 | 09:03 PM
user 98292739's Avatar
Default y7/y8 w/ skunk2 cam gear timing problem
Well here we are again...i had to change head gasket cause timing blew it. My dizzy was all the way forward in order for it to be in time.
anyways block is AEBS sleeved Y7 and head is Y8 both are decked/milled I am not sure how much.
I have a skunk 2 gear on it. i bought the motor like this. I have tried on 3 seperate 5 hour sessions to get it in time. I believe it is one tooth off.
i have never ever messed with cam timing before. I think it is the only way to get it in time. What do you guys think? my friend and i are afraid to adjust the time via cam gear.
Old Mar 4, 2008 | 08:23 AM
RyanA's Avatar
Default Re: y7/y8 w/ skunk2 cam gear timing problem (The Lobster)
Sounds to me like you have a 92-95 cam gear on there. They will make your timing a little off (just about 1 tooth, 4.5 degrees IIRC...) Verify that the cam gear you have is for a Y engine; I think you will find your problem.
Old Mar 4, 2008 | 08:54 AM
Default Re: y7/y8 w/ skunk2 cam gear timing problem (RyanA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanA &raquo;</TD></TR><TR><TD CLASS="quote">Sounds to me like you have a 92-95 cam gear on there. They will make your timing a little off (just about 1 tooth, 4.5 degrees IIRC...) Verify that the cam gear you have is for a Y engine; I think you will find your problem.</TD></TR></TABLE>
how would i verfiy it? its a skunk2 is there a marking or code i should look for?
Old Mar 4, 2008 | 09:01 AM
RyanA's Avatar
Well, now I'm wondering if I'm just confusing myself with the D16a6 and the D15 as they have different deck heights.
Easiest way to verify would be to get a stock Y cam gear and hold it over your cam gear, lining up the keyway (you'll obviously have to remove the cam bolt). Double check the alignment marks on the OEM gear against the S2 cam gear.
Ryan
Old Mar 4, 2008 | 10:36 AM
im hoping there is a code on there or somehting.
i dont exactly have a y8 gear lying around.
but no you are right the z6 head and the y8 head has different timing.
Old Mar 4, 2008 | 12:22 PM
Default Re: (The Lobster)
here is a pic hopefully itll help it had no model numbers on it
Old Mar 4, 2008 | 12:30 PM
Dasfinc's Avatar
4.5* is half a tooth actually, just as reference.
you will HAVE to take the cam bolt off to verify if its for a Z6 or Y8. The Y8 cam gears key way is offset from the 0* mark, while the Z6 key way is perfectly in line with the 0* mark, that is how to tell them apart.
Check out http://www.d-series.org for more on the 'half tooth' issue.
and be aware that if you are off 1 tooth, and have the wrong cam gear and put it all the way to advance you WILL hit your valves (this happened to me, just FYI)
Old Mar 4, 2008 | 12:54 PM
Default Re: (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc &raquo;</TD></TR><TR><TD CLASS="quote">4.5* is half a tooth actually, just as reference.
and be aware that if you are off 1 tooth, and have the wrong cam gear and put it all the way to advance you WILL hit your valves (this happened to me, just FYI)</TD></TR></TABLE>
well crap...ill do this tomarrow...i am running cp 9:1 pistons so hopefully that will prevent me from hitting.
Old Mar 5, 2008 | 07:42 PM
so how many degrees is each mark?
4.5 degrees is how many of those lines?
Old Mar 6, 2008 | 04:11 AM
RyanA's Avatar
1/2 tooth supposedly.
Old Mar 6, 2008 | 09:32 AM
sorry i meant each mark is 2 degrees but i need 4.5 so that would be like 2.2 marks. do i just guess on the .2 mark?
Old Mar 6, 2008 | 01:19 PM
RyanA's Avatar
Yes, 1 mark is 2 degrees so you'll just have to "guess" on the points between the marks.
austen95
Mar 12, 2018 06:55 PM
doublezerohatch
23
Jun 2, 2013 04:38 PM
kUrb3d
Aug 4, 2010 05:55 AM
adbodykits
Aug 17, 2009 05:21 PM
Cuong-nutz
Jun 24, 2005 02:27 PM
