mini-me with jdm zc and d15b head anyone ever did it?
Old Mar 3, 2008 | 07:27 PM
team2dcrx's Avatar
Default mini-me with jdm zc and d15b head anyone ever did it?
what would be a safe rpm redline i am not to sure if it depends on the block or the head
thanks norris
Modified by team2dcrx at 12:24 PM 3/11/2008
Old Mar 3, 2008 | 10:25 PM
mario_pic's Avatar
Default Re: mini-me with jdm zc and d15b head anyone ever did it? (team2dcrx)
its the same as a jdm vtec just usdm lol but the cams will be diffrent thats all
Old Mar 3, 2008 | 11:05 PM
whiteknightef's Avatar
Default Re: mini-me with jdm zc and d15b head anyone ever did it? (mario_pic)
Im sure it will be different. Have your machine shop spec out the compression ratio.
Or use this calculator:
http://www.zealautowerks.com/dseries.html
Old Mar 4, 2008 | 12:44 AM
zcmotor's Avatar
Are the Zc single cam with a Vtec head fast ? and from what block does the Vtec head come from?
Old Mar 4, 2008 | 07:17 AM
team2dcrx's Avatar
Default add boost
i heard the compression ratio on the zc is like 10.1 or 10.5.1
and what do you think about boost?
Old Mar 5, 2008 | 09:03 AM
photostillshot's Avatar
no the compression is 12.03.1. im looking into this swap my self g/l
Old Mar 5, 2008 | 09:04 AM
nm nm your going to use the zc head lmao?
Old Mar 11, 2008 | 11:25 AM
team2dcrx's Avatar
bump what about the redline cause the sohc vtec is 7500 and the a6 is 6500
Old Mar 11, 2008 | 02:16 PM
143MYVTECEF's Avatar
the best RPM is what a dyno graph tells you it is. i could tell you take it to 7500 but what if you only make peak power at 6800 whats the point of wasting 700 rpms. point is build you motor, tune it, have fun
mymeatb18"
43
Sep 21, 2019 12:14 AM
Baserloks
10
Dec 23, 2015 07:28 AM
spens 91 Ef
Sep 13, 2009 09:04 PM
91ZCcivicSi
Feb 5, 2005 07:12 PM
E dwinbon G
Jan 20, 2003 07:52 AM
