Crower rod installation?
Old Mar 3, 2008 | 07:27 PM
88Hatchy's Avatar
Default Crower rod installation?
I recently purchased a set of crower maxi-light rods. It does not specify anywhere in the packaging which way the rods "face". For example, factory rods have a stamping that faces forwards in the block. Which way do they go? Does it even matter? (I assume it does)
Old Mar 3, 2008 | 07:59 PM
Agnom's Avatar
Default Re: Crower rod installation? (88Hatchy)
I've just installed a set of Crower Maxi-light rod in my B18C1, put about 3000miles on it, rev up pretty quick if match with forged pistons, i don't think it matters, give Crower a call. You are gonna love the rods
Old Mar 3, 2008 | 08:12 PM
nam3less's Avatar
Default Re: Crower rod installation? (Agnom)
Doesn't matter, just a tool to use for lining up the pistons and rings ... just be consistant.
Old Mar 4, 2008 | 02:47 AM
88Hatchy's Avatar
Default Re: Crower rod installation? (nam3less)
What about the notches that hold the bearings? Do they have to be aligned a certain way? Intake or exhaust side?
Old Mar 4, 2008 | 07:30 AM
Garcia-Racing's Avatar
Tangs on the exhaust side.
Old Mar 4, 2008 | 05:09 PM
88Hatchy's Avatar
thanks for the info
Old Mar 7, 2008 | 05:37 PM
88Hatchy's Avatar
I guess it's time to come clean. The motor has been assembled for 10 months and is actually running in the car right now. How critical is it for the tangs to be on the exhaust side? The motor runs fine as of right now, but if it is critical then it will be corrected before it is started again. The engine only has about 200 miles on it.
GABOCRX
Sep 9, 2009 08:21 AM
kuki22
Honda Civic (2001 - 2005)
15
Dec 9, 2007 11:55 AM
EKB18BPR3
Oct 24, 2004 05:31 PM
JMinSi2000
May 8, 2003 12:05 AM
TheSwift1
Oct 26, 2002 09:27 PM
