help! bolt wont come out!
ok so i just bought some skunk2 lowering springs for my car and ive been following installation instructions from this site: http://www.hazone.com/hciv5spring.htm
everything is going fine except i cant remove my lower control arm bolt (which is step 4 on the site)
i dont have an impact gun and wd-40 isnt doing the trick soo any suggestions or tips?
i would really appreciate the help,
thanks.
thanks.
My problem wasn't that the bolt was stuck. Well, is was in a different type of way. The nut loosened a little then it just kept spinning without it actually loosening anymore since the top part kept spinning with the nut. I ended up having to cut the bolt and got a new tie rod (I was replacing the tie rod anyway). You're reffering to the castle nut correct?
moleodonuts
19
Jan 10, 2005 02:07 PM
