Built Single Cam turbo Non VTEC
Old Feb 29, 2008 | 09:22 PM
x82d's Avatar
Default Built Single Cam turbo Non VTEC
Hello, im new to honda-tech and honda's in general. I am trying to figure out what the best D series motor to boost is, and what parts i need to get to build the motor up properly to handle 20+psi
I want dont want to run a B series i want to stick with D series NON V-TEC turbo hopefully with a GT30 or a TD04 since i have those two turbos allready.
Any insite on parts to get would be great...
Thanks
Old Feb 29, 2008 | 09:42 PM
Got traction's Avatar
Default Re: Built Single Cam turbo Non VTEC (x82d)
http://www.turbod16.com is a good place to read up. im running a vitara set up on my y8. dont set your goal as psi, set a whp goal and work from there.
Old Feb 29, 2008 | 09:47 PM
EJcivicJDM7's Avatar
um....you wanna boost a non-vtec? If you wanna stick with a D series why not swap your non vtec with a D series that has V tec? Idk. Imo, it seems pointless to boost the motor you have. And your going to be spending a lot more money to build a single cam, stick with a b series.
but to answer your question. a JDM D15B or D16z6, D16y8 would be more suitable for boost.
Old Feb 29, 2008 | 09:50 PM
user 98292739's Avatar
Default Re: Built Single Cam turbo Non VTEC (EJcivicJDM7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcivicJDM7 &raquo;</TD></TR><TR><TD CLASS="quote">um....you wanna boost a non-vtec? If you wanna stick with a D series why not swap your non vtec with a D series that has V tec? Idk. Imo, it seems pointless to boost the motor you have. And your going to be spending a lot more money to build a single cam, stick with a b series.
but to answer your question. a JDM D15B or D16z6, D16y8 would be more suitable for boost. </TD></TR></TABLE>
no you dont have to spend mroe money on a SOHC...takes 2k to sway in a b series.
with 2k you could get a z6 long block and vitara piston and eagle rods for under a grand...and then have a grand to spend on a turbo kit that could potentially push 300=400 hp SOHC daily driven...
Old Feb 29, 2008 | 10:36 PM
ddd4114's Avatar
PSI is arbitrary. Plan for a power goal, not a pressure goal.
A d16a6 is the engine you're looking for. It's a SOHC non-VTEC, and it's just as stout as the other SOHC's, VTEC included.
derger207
31
Jun 11, 2010 03:09 PM
foxdecoy
Dec 8, 2008 10:30 AM
x82d
Mar 1, 2008 09:25 AM
radmxracer72
Jul 19, 2005 11:05 AM
albert
Jan 30, 2005 09:37 PM
