Plz help I have a CTR Head i want to run ITR PISTON?
Old 02-29-2008, 10:16 PM
eg6-trans's Avatar
Default Plz help I have a CTR Head i want to run ITR PISTON?
I have a ctr internal head. I can pick up a set of ITR piston for 175. What do u guys think about that build? ANy bad thing about itr with ctr cams. I know itr has less copression then ctr. but any bad thing will happen if i run with those two? Plz help. Any suggestion would be great. Plz
Old 02-29-2008, 10:17 PM
BlueIntegraBoy's Avatar
Default Re: Plz help I have a CTR Head i want to run ITR PISTON? (eg6-trans)
Nothing bad, make sure you get your engine tuned.
If the setup is using a 1.8L block with ITR internals, you basically have a 00-01 ITR engine.
Old 02-29-2008, 10:32 PM
eg6-trans's Avatar
Default Re: Plz help I have a CTR Head i want to run ITR PISTON? (BlueIntegraBoy)
am running b20b4 block
Old 02-29-2008, 10:40 PM
The ITR pistons won't fit in the B20 block. The pistons are 81mm (bore) and the B20 sleeves are 84mm.
EGtypeR408
10-12-2010 01:12 AM
maxaldinger
06-16-2008 02:57 PM
eg6-trans
03-01-2008 09:02 AM
aintnothing
10
01-29-2006 05:45 PM
civicrsx93
13
11-03-2004 01:53 PM
Quick Reply: Plz help I have a CTR Head i want to run ITR PISTON?
