quick question and i got pics
Old Feb 29, 2008 | 03:42 PM
advan414's Avatar
Default quick question and i got pics
hey i been worried about my wiring i got a b18c obd1 and a 96 obd2 civic and i was wondering if the harness plug fits into the shock tower(firewall) please dont tell me stuff about changing to obd2 or anything i already got a obd1 p28 with conversioon harness i just want to know if these obd1 harness plugs fit into my obd2 shock tower.
Old Feb 29, 2008 | 03:46 PM
jax97hx's Avatar
Default Re: quick question and i got pics (advan_turbo_gsr)
have you tryed them to see if they fit?
Old Feb 29, 2008 | 03:50 PM
advan414's Avatar
Default Re: quick question and i got pics (jax97hx)
to cold and my uncle takes my car to work till we get his 240 painted
Old Feb 29, 2008 | 04:35 PM
hondgod's Avatar
you will be modifying and reusing your stock engine harness or buying a 96-98 ex engine harness anyway so it doesn't really matter. But if your talking about pluging in a b18c harness to a skock tower on an ek then the answer is no they dont fit. duct tape, hot glue and a torch would make them fit though.
Old Feb 29, 2008 | 04:51 PM
advan414's Avatar
Default Re: quick question and i got pics (hondgod)
all the wires line up? if so ill just fabricate it
Old Feb 29, 2008 | 07:10 PM
CivicSpoon's Avatar
No, you can't use the OBD1 harness, because it's a 2 piece harness. Your '96 Civic has a 1 piece harness, meaning the harness goes to the engine all the way to the ecu. The 2 piece (OBD1) goes from the engine to the shock tower plugs (1st harness), the shock tower plugs then go to the ecu (2nd harness). So you HAVE to use the stock '96 OBD2A Civic engine harness. Just as a side note, OBD2 Integras also have the 2 piece harness.
Old Feb 29, 2008 | 07:14 PM
advan414's Avatar
Default Re: (CivicSpoon)
ok thanks so im gonna have to do some cut and splicing with my obd1 and obd2 harness and rewire vtec?
Old Feb 29, 2008 | 08:33 PM
x0!'s Avatar
x0!
what kind of conversion harness do you have? mine came ready for vtec.
Old Feb 29, 2008 | 10:30 PM
advan414's Avatar
Default Re: (x0!)
i just got the obd 2 to obd1 ecu conversion (just like the boomslang) for converting the 96 civic obd2 connectors to my obd1 ecu
Old Mar 1, 2008 | 08:06 AM
CivicSpoon's Avatar
The only differences you should really have to worry about, besides adding the vtec wires, is the distributor plug, alternator plug, and injectors (you could just use the OBD2 injectors). Everything else should be plug and play.
Old Mar 1, 2008 | 08:21 AM
sicones's Avatar
https://honda-tech.com/zerothread?id=558245
/thread
adamrich33
Mar 10, 2008 11:44 AM
Cuda
Jan 16, 2008 06:18 AM
brkdwn5
Jun 28, 2006 06:03 PM
civtegra_hybrid
Sep 14, 2004 01:29 AM
