quick question and i got pics
hey i been worried about my wiring i got a b18c obd1 and a 96 obd2 civic and i was wondering if the harness plug fits into the shock tower(firewall) please dont tell me stuff about changing to obd2 or anything i already got a obd1 p28 with conversioon harness i just want to know if these obd1 harness plugs fit into my obd2 shock tower.
Re: quick question and i got pics (advan_turbo_gsr)
you will be modifying and reusing your stock engine harness or buying a 96-98 ex engine harness anyway so it doesn't really matter. But if your talking about pluging in a b18c harness to a skock tower on an ek then the answer is no they dont fit. duct tape, hot glue and a torch would make them fit though.
No, you can't use the OBD1 harness, because it's a 2 piece harness. Your '96 Civic has a 1 piece harness, meaning the harness goes to the engine all the way to the ecu. The 2 piece (OBD1) goes from the engine to the shock tower plugs (1st harness), the shock tower plugs then go to the ecu (2nd harness). So you HAVE to use the stock '96 OBD2A Civic engine harness. Just as a side note, OBD2 Integras also have the 2 piece harness.
Re: (x0!)
i just got the obd 2 to obd1 ecu conversion (just like the boomslang) for converting the 96 civic obd2 connectors to my obd1 ecu
The only differences you should really have to worry about, besides adding the vtec wires, is the distributor plug, alternator plug, and injectors (you could just use the OBD2 injectors). Everything else should be plug and play.
