b16 turbo smokes at idle
Old Feb 29, 2008 | 10:03 AM
hondastreets1's Avatar
Default b16 turbo smokes at idle
it only smokes after the car is ran for a few minutes it smells like oil smoke may the turbo is bad any other suggestions
Old Feb 29, 2008 | 10:21 AM
egmatt93's Avatar
Default Re: b16 turbo smokes at idle (hondastreets1)
check ur charge piping right off the turbo if there oil leaking through the coupler then the turbo seals are prob bad, if not then valve seals, rings
Old Feb 29, 2008 | 10:25 AM
Default Re: b16 turbo smokes at idle (egmatt93)
so if no oil in charge pipe check compression?
Old Feb 29, 2008 | 10:34 AM
egmatt93's Avatar
yea give it a shot
Old Feb 29, 2008 | 10:38 AM
k thanks for info and also runnin on stock dizzy at 15lbs of boost and its startin to break up im kinda wondering if its fouling the plugs or if it is seals leakin into cylinder gumming them with oil thanks for input ill gett on it and see what i can find
Old Feb 29, 2008 | 11:13 AM
figured out my problem maybe. i have no catch can
cardsfan
Dec 6, 2011 03:03 PM
4doorpowa
May 27, 2011 04:37 AM
arayam1624
Nov 8, 2010 05:07 PM
GEN2 LS
Jul 3, 2008 04:59 AM
txspooln
Nov 14, 2003 07:54 AM
