b16 turbo smokes at idle
it only smokes after the car is ran for a few minutes it smells like oil smoke may the turbo is bad any other suggestions
Re: b16 turbo smokes at idle (hondastreets1)
check ur charge piping right off the turbo if there oil leaking through the coupler then the turbo seals are prob bad, if not then valve seals, rings
Re: b16 turbo smokes at idle (egmatt93)
k thanks for info and also runnin on stock dizzy at 15lbs of boost and its startin to break up im kinda wondering if its fouling the plugs or if it is seals leakin into cylinder gumming them with oil thanks for input ill gett on it and see what i can find
