Oil Temp Gauge
Old Jul 6, 2002 | 09:34 AM
Ryuji's Avatar
New User
Default Oil Temp Gauge
I would like to know if there is a easy way to install such a gauge on a ITR.
Old Jul 6, 2002 | 10:02 AM
D's Avatar
D
Default Re: Oil Temp Gauge (Ryuji)
yup.
Drill a hole in your Oil pan, tap it, insert sender, and wire the bisch up.
D
Old Jul 6, 2002 | 12:42 PM
Ryuji's Avatar
New User
Default Re: Oil Temp Gauge (D)
It is what I thought, not as easy !!!
Thanks
Old Jul 6, 2002 | 01:12 PM
JM Performance's Avatar
I think they make sensors that screw into and replace your drain bolt....now thats easy. I think GReddy makes them...autometer might too.
Old Jul 6, 2002 | 02:11 PM
D's Avatar
D
Default Re: Oil Temp Gauge (00SilverLS)
autometer's sending unit is too large for our drain bolt.... you would ahve to bore out a GOOD bit of material to thread the autometer sending unit into our drain plug. I would NOT suggest doing so. Not sure of other options for sending units from other manufaturers.
D
Old Jul 6, 2002 | 07:31 PM
EagleR's Avatar
Z-10 makes one I heard....never seen one in real life though, so anything I could say about fitment would be hearsay
Old Jul 6, 2002 | 07:39 PM
bus stop's Avatar
yup.
D
Do I need to remove the oil pan to do that? I'm worry about the "deposit" from drilling may get to the inside (of the oil pan).
Old Jul 7, 2002 | 02:56 AM
MackSpeed-616's Avatar
Default Re: Oil Temp Gauge (WhosITR)
yes..
Old Jul 7, 2002 | 05:40 AM
D's Avatar
D
Default Re: Oil Temp Gauge (BustaNutt-616)
if you feel like it, you can coat your drill bit and tap in petroleum jelly, and most if not all of the chips will be retained on the outside of the pan. flush with a bit of oil, and be done with it.
your choice.
D
GUILOTINE
10
Feb 3, 2005 09:36 PM
m R g S r
Jan 12, 2005 06:53 PM
KStuned
Mar 13, 2004 12:33 AM
Hondasaurs
May 14, 2003 08:12 AM
Bloodwynch
Jan 22, 2002 07:18 AM
