Where to tap for oil temperature gauge?
Where should I tap for an oil temperature sender on a B17?
I am planning on tapping in the back of the head where you would if you were doing an LS/VTEC on an LS head, is this OK?
Is there anywhere particular that I should tap that will give me an accurate reading?
Re: Where to tap for oil temperature gauge? (Hondaddict)
I wouldn't worry about the oil temp gauge as much as the oil pressure gauge. Do you already have the pressure gauge?
Re: Where to tap for oil temperature gauge? (m R g S r)
Irrelevant to my question but yes, I have installed the oil pressure, water temp, boost, egt, and AEM AFR gauge.
I need to know where I should tap for oil temp.
Please no more responses about what OTHER gauges I should have. THanks. (this is not for my car by the way)
Re: Where to tap for oil temperature gauge? (MordecaiPSI)
i have always thought having it on the pan is better since its after its been in the motor so its a more true temp of the oil
Re: Where to tap for oil temperature gauge? (Haberdasher)
On the oil pan.. there are also sensors with which you just replace original drain screw in oil pan, so no hassle to install.
CRVTEC0WNZJ00
10
10-03-2005 07:45 AM
