b20 or gsr?
What block are you using, i assume the b20, right? the gsr would require special pistons to work. i have heard of the gsr cranks handling over 700 hp, but never heard on the b20. i think the gsr crank is cast, like the b20 crank is, but not sure. from what i have seen, the gsr will work in the b20 block, as far as bearing journal sizes, so its your call.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daver »</TD></TR><TR><TD CLASS="quote">which ever costs more is better </TD></TR></TABLE> that is not necessarily true, if you research the cranks, you may see alot in common, but everyone may think one is better, so they would pay more for that.
