CTR pistons in b16a2
Old Feb 26, 2008 | 12:32 PM
2ToneEM1's Avatar
Default CTR pistons in b16a2
I will soon be rebuilding the block on my b16a2 and was concidering running some ctr pistons to raise compression, i know the rods will need to be machined but will anything else need to be modified and what will be the compression?
Thanks
Old Feb 26, 2008 | 01:02 PM
King V's Avatar
Default Re: CTR pistons in b16a2 (2ToneEM1)
CTR pistons are OK to use and lots of people do/have, but there are better/easier choices out there as far as aftermarket pistons. If you want OEM pistons, I would go with ITR P73 pistons. They're not as heavy as CTR pistons(310 grams for ITR, 327 for CTR, 299 for stock B16)and the compression height/ dome isn't as outrageous as the CTR pistons. I think going with an aftermarket piston set you will have an easier time getting what you want out of the engine instead of piecing it together and hoping you get what you want.
Old Feb 26, 2008 | 01:16 PM
2ToneEM1's Avatar
Default Re: CTR pistons in b16a2 (King V)
Ok what would you recommend? Im wanting around 11:1 compression
Old Feb 26, 2008 | 02:05 PM
stock ek's Avatar
im also doing a b16a2 build and im going with p30 pistons there going to give me about 10.7-1 with the stock headgasket and if i would use a 2 layer i would i think ill be at about 10.9-1 which is right were i wanna be and they are only like $130 which is pretty good price i think.
Old Feb 26, 2008 | 02:44 PM
jaaaameSI's Avatar
I am doing the same to my Si. I have been lookin aroud and foun that on Acuraautomotiveparts.org they have ITR pistons, wrist pins and rings for just about 300. OE honda parts are always a plus and they will put you right at 11.1-1.
ofcoarse your going to have to get some block work done to make them fit.
Old Feb 26, 2008 | 02:51 PM
2ToneEM1's Avatar
Does anything need to be modified to run the p30s?
And what kind of block work to run the ITRs?
Old Feb 26, 2008 | 02:56 PM
Padawan's Avatar
Darth ModerVader
ITR pistons in the B16 block are going to lower compression, not raise it.
Old Feb 26, 2008 | 03:31 PM
stock ek's Avatar
Default Re: CTR pistons in b16a2 (Padawan)
no you can get standard sizes and all i would do is just refresh it with a hone job and what not, but they should just fit right in, ohh by the way i got mine from http://www.hmotorsonline.com
Old Feb 26, 2008 | 04:10 PM
2ToneEM1's Avatar
Default Re: CTR pistons in b16a2 (stock ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock ek &raquo;</TD></TR><TR><TD CLASS="quote">no you can get standard sizes and all i would do is just refresh it with a hone job and what not, but they should just fit right in, ohh by the way i got mine from http://www.hmotorsonline.com</TD></TR></TABLE>
Ok cool, ill just do that then
Unphzd
Oct 6, 2011 12:07 AM
Ruben19
19
Jan 9, 2006 09:13 AM
aris04
Jun 7, 2004 12:03 PM
wickedEFguy
Jan 21, 2003 03:14 PM
jsalicru
Dec 20, 2002 03:13 PM
