height issues b18c5 hood?
Old Feb 26, 2008 | 11:09 AM
rewerbcrx's Avatar
Default height issues b18c5 hood?
i had a problem while building my crx with the C5 in height. i was curious if there is any issues with hood cleaence with the del sol?
i did search. civics came up ( b18c5 fit:searched)
Old Feb 26, 2008 | 11:20 AM
Luserkid's Avatar
Default Re: height issues b18c5 hood? (rewerbcrx)
Only problems i know of is with old school VIS hoods. As far as i know they change the design so they do not hit anymore. Other then that you should be good.
Old Feb 27, 2008 | 04:28 PM
rewerbcrx's Avatar
Default Re: height issues b18c5 hood? (Luserkid)
any other def answers?
Old Feb 27, 2008 | 05:31 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">any other def answers?</TD></TR></TABLE>
Check the 88-91 civic/crx forum.
Old Feb 28, 2008 | 11:28 AM
rewerbcrx's Avatar
Default Re: height issues b18c5 hood? (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Check the 88-91 civic/crx forum.</TD></TR></TABLE>
OKAY... pointless reply... i already stated i know about the crx and the b18c5.... DUh
i need to know def answers to the del sol... i already know the hieght differences i put a b18c5 in my crx!
Old Feb 28, 2008 | 11:44 AM
del_slow420's Avatar
im running a turboed lsvtec in my del sol.. it came with the b16.. i had a little rubbing of the valve cover on the hood very minor i just took washers and longer bolts for my hood hinge's and it solved it.. i dont know if you want a lifted hood though
Old Feb 28, 2008 | 08:08 PM
rewerbcrx's Avatar
Default Re: height issues b18c5 hood? (del_slow420)
thank you ... that is exactly what i wanted to here... that means the b18c5 would REALLY rub... and i def don't want a raised hood...
does anyone know if they make a CF hood for the del sol that raises up... <U>like</U> the JDM up bump from VIS for the crx
Old Feb 28, 2008 | 08:11 PM
Thateguhate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Only problems i know of is with old school VIS hoods. As far as i know they change the design so they do not hit anymore. Other then that you should be good. </TD></TR></TABLE>
yup, i had a double sided VIS and that thing fell victim to my motor going through it... I wanted to cry..
Old Feb 28, 2008 | 09:17 PM
Uxi's Avatar
Uxi
Default Re: height issues b18c5 hood? (Thateguhate)
I always thought the EK and EG areas should be separated. Search is one of the reasons.
Old Feb 29, 2008 | 08:47 AM
rewerbcrx's Avatar
Default Re: height issues b18c5 hood? (Uxi)
so for the "old" vis hods its a no go... do they make a bumped up hood or not?
more help on this would be great... for future swappers
Old Feb 29, 2008 | 09:36 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">thank you ... that is exactly what i wanted to here... that means the b18c5 would REALLY rub... and i def don't want a raised hood...
No, b16's do not rub they come with that motor from the factory with plenty of clearance.
Old Feb 29, 2008 | 11:12 AM
rewerbcrx's Avatar
Default Re: height issues b18c5 hood? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
No, b16's do not rub they come with that motor from the factory with plenty of clearance. </TD></TR></TABLE>
the b18c5 head is 8mm taller than the b16 you obviously don't know whatyour talking about
Old Feb 29, 2008 | 11:34 AM
nsxmatt's Avatar
the b18c5 head is 8mm taller than the b16 you obviously don't know whatyour talking about</TD></TR></TABLE>
I wasn't talking about the B18c5 I was talking about the B16 you quoted the previous post about his setup rubbing. I am very aware the height difference between the motors, I was only clarifiying his statement saying there is plenty of clearance with the stock B16. Learn to read dumbass if your going to ask people for help and be a *** to them.
Old Mar 1, 2008 | 10:54 AM
rewerbcrx's Avatar
obviosly your reply has nothing to do with the OP... and i don't care one bit about a b16... try to keep up and stay on topic...
Old Mar 1, 2008 | 11:36 AM
hall97civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">obviosly your reply has nothing to do with the OP... and i don't care one bit about a b16... try to keep up and stay on topic...</TD></TR></TABLE>
quit being a *****. His post is on topic because he was correcting previous info that was incorrect. A b16 came factory, so trust me, it will fit with plently of room, so if you use a stock hood with a b18, it should fit. There's your answer dumbass.
Old Mar 1, 2008 | 12:46 PM
instrument's Avatar
if b18c's fit with no problem why would a c5 find issue?
Old Mar 1, 2008 | 10:23 PM
rewerbcrx's Avatar
Default Re: (instrument)
i would like to talk to someone that has a c5 in their del sol with a CF hood. instead of spectators guessing. thank you
honda_aj
10
Jan 21, 2008 01:21 PM
bluelxfodo
Classic Hondas
16
Jan 6, 2008 07:11 PM
PINKS
10
May 15, 2006 04:39 PM
hondaboy90
Sep 8, 2005 07:12 AM
cxvtec
Jul 22, 2004 10:11 AM
