DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs
Old Feb 26, 2008 | 09:24 AM
BrakeExpert's Avatar
Default DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs
problem
Old Feb 26, 2008 | 09:31 AM
roastbeefrichie's Avatar
Default Re: DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs (BrakeExpert)
...how come you didn't tell me how good the cheese was !
Old Feb 26, 2008 | 09:45 AM
2fast4u831's Avatar
I'm really 2slow
damn man. I might need to get these once I come up with some money
Old Feb 26, 2008 | 11:26 AM
B16B_coupe's Avatar
HRD PKR
Default Re: DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs (96hatchy)
Cant wait to get my setup, Curious... what other rear caliper setup can you run with this rotor?
Old Feb 26, 2008 | 09:12 PM
Default Re: DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs (B16B_coupe)
Nothing on a disc spindle. If you have drums, you can use this rotor plus a custom drum to disc adapter plate and run ITR calipers/pads/brackets on this rotor for more bite.
Also you can use a custom adapter to run 300ZX calipers (opposed 2 piston) but you will have no e-brake so I'm not going to design a bracket for that application since there was no demand for rear Legend calipers (lighter and no e-brake in em)
Old Feb 26, 2008 | 09:59 PM
wudini's Avatar
from what i can see this upgrade is going to do nothing but add weight. the caliper is contacting exactly the same surface area of a bigger rotor that it was with the smaller one. am i missing something?
Old Feb 26, 2008 | 10:48 PM
Default Re: DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs (wudini)
It uses a bigger rotor (adds a bit of weight but not much since the hat is smaller) and thus increases brake torque. imagine grabbing a CD spinning on a shaft. Then imagine grabbing the edge of a record spinning on that same shaft. You can stop the record better because its diameter is greater. Maybe I'm doing a bad job of explaining this.
Man, everyone seems to hate this setup, I'm gonna scrap it. The fast brakes relocator kits dont sell much either.
Old Feb 27, 2008 | 03:20 AM
newby_j's Avatar
Needs More Cowbell
I don't think that it is a bad setup. I just am wondering that if someone does the upgrade to this, what is an affordable front setup to keep the bias?
Old Feb 27, 2008 | 07:09 AM
Default Re: DIY: 11.1" rear disc upgrade for Civics with 9.4" rear discs (newby_j)
The Type-R front setup would balance out well. It uses 11.1" rotors and the Type-R caliper/bracket/pad which is much bigger to even out the correct bias. It can be modified to be used on a 4x100 Integra or Civic EX knuckle.
Old Nov 8, 2008 | 07:42 AM
g2_teg_'s Avatar
any pictures of this installed?
Old May 11, 2009 | 01:33 AM
fc3srx729's Avatar
bump for pics...
Old May 11, 2009 | 03:38 AM
BryanM.'s Avatar
Resident Gearhead
BrakeExpert was banned...
Old Jul 24, 2009 | 08:19 AM
fc3srx729's Avatar
Serious, What For...?
Old Jul 24, 2009 | 03:47 PM
BryanM.'s Avatar
Resident Gearhead
For complaining about the switch from ZeroForum to vB IIRC.
Sucks, the guy really knows his ****.
Worst part is he erased all his pics/info from all his threads. Some threads were increadible, must have taken weeks to make some of them.
Old Jul 25, 2009 | 08:21 AM
fc3srx729's Avatar
Damn...! I wanted to upgrade my brakes through him, Would you or somebody have a contach number, e-mail, or website so I can get a hold of him...? Thanks everyone...
Old Jul 25, 2009 | 08:30 AM
ej1love's Avatar
word
Old Jul 25, 2009 | 10:45 AM
B-outAteam's Avatar
bumb
SOHC_me
Oct 9, 2006 01:51 AM
Rash Ej1 SiR
May 5, 2006 09:27 PM
fastbrakes
Oct 26, 2001 10:23 PM
2fcknfst
Oct 8, 2001 06:02 PM
