Your thoughts on this
My 91 RHD da is making me scratch my head
ok i replaced the dizzy,
new starter
new battery
new spark plugs
when i drive it in first at low RPM its koo
but when i step on the gas it boggs out and sometime the whole car shuts off
what are your thougts??
new starter
new battery
new spark plugs
yes sir timing correct..
When I start the car it runs perfect just sitting there idle is perfect like 900
but when I start to drive it it boggs out than shuts off the motor everything else is on the lights,radio,and so forth just the motor shuts off...
Still scratching my head
Engine starts but stops immediately
- Loose or faulty electrical connections at distributor, ignition coil or alternator.
- Insufficient fuel reaching the fuel injectors.
- Vacuum leak at the gasket between the intake manifold and throttle body.
__________________________________________________ _______________
Engine stumbles on acceleration
- Spark plugs fouled.
- Fuel injection system faulty.
- Fuel filter clogged.
- Incorrect ignition timing.
- Intake manifold air leak.
Engine surges while holding accelerator steady
- Intake air leak.
- Fuel pump faulty.
- Loose fuel injector wire harness connectors.
- Defective ECU or information sensor.
Engine stalls
- Idle speed incorrect.
- Fuel filter clogged and/or water and impurities in the fuel system.
- Distributor components damp or damaged.
- Fault emissions system components.
- Faulty or incorrectly gapped spark plugs.
- Faulty spark plug wires.
- Vacuum leak in the fuel injection system, intake manifold or vacuum hoses.
- Valve clearances incorrectly set.
- Intake air leak.
- Fuel pump faulty.
Engine stalls
teg racer 877
Apr 7, 2010 09:53 PM
jimmy o.
13
May 16, 2009 08:36 AM
