Car will not run...?
Old Feb 25, 2008 | 04:09 PM
mike03,95civic's Avatar
Default Car will not run...?
I searched a lot before i posted this and found some info that could be my problem but i would like input on my situation.
I have a '95 civic with a b18b. I haven't had any broblems recently but today i drove it and parked it and turned the car off. Then 1 min. later i try and start it again and it won't start. The car acts like the battery is dead. all the power seems to be out but I took a volt meter and the battery is fine. I checked the grounds and I checked the starter and distributor have power. The fuses in the engine bay are also fine. I read that that it could be the main relay? What could be the problem? Thank you very much for any help
Old Feb 25, 2008 | 04:21 PM
Default Re: Car will not run...? (mike03,95civic)
Just to add on a little from before, when i put the key in the ignition with the car door open it beeps, but it doesn't make any noise going into accessories mode and dash does not light up. power door looks also do not work. When trying to start the car does not make any noise.
Old Feb 25, 2008 | 04:59 PM
Can anybody tell me what it could be? Or what its not?
Old Feb 25, 2008 | 05:01 PM
rotascircuit's Avatar
your piston rings are out
Old Feb 25, 2008 | 05:08 PM
Default Re: Car will not run...? (rotascircuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotascircuit &raquo;</TD></TR><TR><TD CLASS="quote">your piston rings are out</TD></TR></TABLE>
Why would that cause the electrical problems?
Old Feb 25, 2008 | 05:12 PM
eg8tuner's Avatar
im thinking it could be your ignition switch but that just a shot in the dark becasue every thing else seems fine.
Old Feb 25, 2008 | 05:14 PM
Default Re: (eg8tuner)
How would you check if its the ignition switch?
Old Feb 25, 2008 | 05:16 PM
95delsolz6's Avatar
You don't hear your fuel pump prime? I would look into the main relay.
Old Feb 25, 2008 | 05:17 PM
eg8tuner's Avatar
you could take it out and check for continuity across some of the terminals. there should be a wiring diagram for it some were on the internet.
Old Feb 25, 2008 | 05:18 PM
eg8tuner's Avatar
if it is the main relay some times tapping it will get it to work again for a little bit
sorry i thought u said u all ready checked that i wouldn't send u ripping apart your column if u did.
Old Feb 25, 2008 | 05:19 PM
Default Re: Car will not run...? (95delsolz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95delsolz6 &raquo;</TD></TR><TR><TD CLASS="quote">You don't hear your fuel pump prime? I would look into the main relay.</TD></TR></TABLE>
How would you check the main relay?
Old Feb 25, 2008 | 05:21 PM
eg8tuner's Avatar
with a volt meter there has to be a procedure on her some were but u should here it tick if it is working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8tuner &raquo;</TD></TR><TR><TD CLASS="quote">if it is the main relay some times tapping it will get it to work again for a little bit
sorry i thought u said u all ready checked that i wouldn't send u ripping apart your column if u did.</TD></TR></TABLE>
No problem... I'm looking for suggestions
Old Feb 25, 2008 | 05:23 PM
sorry i don't know very much about electrical... is the main relay under the dash or in the engine bay?
Old Feb 25, 2008 | 05:28 PM
eg8tuner's Avatar
it in the driver side kick panel or just above it i belive
Old Feb 25, 2008 | 05:33 PM
Alright I check that tomorrow. so just check for valtage and when i try starting the car it should make a clicking noise?
Anybody else have anything else I should look into?
Old Feb 25, 2008 | 05:42 PM
EG6 Love's Avatar
sounds like a loose conection on the battery but im sure if your smart enough to put in a b18b u prolly already check the conections. i had a problem with my main relay but when i turned the key i didnt get anything. but u should replace it anyways. i heard that blowing on the relay cools it down to make it work. heat it wat makes it crap out.
Old Feb 25, 2008 | 05:45 PM
Default Re: (EG6 Love)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Love &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a loose conection on the battery but im sure if your smart enough to put in a b18b u prolly already check the conections. i had a problem with my main relay but when i turned the key i didnt get anything. but u should replace it anyways. i heard that blowing on the relay cools it down to make it work. heat it wat makes it crap out. </TD></TR></TABLE>
Yeah the conection to the battery is tight. I'll check on the relay. How much do they cost?
Old Feb 25, 2008 | 06:04 PM
Default Re: (mike03,95civic)
I've been searching about main relays and it sounds like most people still have power to lights, clock, gauges... I don't. Could main relay cause loss of power to these things?
95civlx
Jan 24, 2011 06:18 AM
95civlx
Nov 23, 2010 05:47 AM
matmcg
Nov 16, 2007 06:58 AM
rokwilder1
33
Jun 28, 2006 10:49 AM
Elemental
Sep 7, 2004 02:08 PM
