Car will not run...?
I searched a lot before i posted this and found some info that could be my problem but i would like input on my situation.
I have a '95 civic with a b18b. I haven't had any broblems recently but today i drove it and parked it and turned the car off. Then 1 min. later i try and start it again and it won't start. The car acts like the battery is dead. all the power seems to be out but I took a volt meter and the battery is fine. I checked the grounds and I checked the starter and distributor have power. The fuses in the engine bay are also fine. I read that that it could be the main relay? What could be the problem? Thank you very much for any help
Re: Car will not run...? (mike03,95civic)
Just to add on a little from before, when i put the key in the ignition with the car door open it beeps, but it doesn't make any noise going into accessories mode and dash does not light up. power door looks also do not work. When trying to start the car does not make any noise.
Re: Car will not run...? (rotascircuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotascircuit »</TD></TR><TR><TD CLASS="quote">your piston rings are out</TD></TR></TABLE>
Why would that cause the electrical problems?
if it is the main relay some times tapping it will get it to work again for a little bit
sorry i thought u said u all ready checked that i wouldn't send u ripping apart your column if u did.
Re: Car will not run...? (95delsolz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95delsolz6 »</TD></TR><TR><TD CLASS="quote">You don't hear your fuel pump prime? I would look into the main relay.</TD></TR></TABLE>
How would you check the main relay?
Re: (eg8tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8tuner »</TD></TR><TR><TD CLASS="quote">if it is the main relay some times tapping it will get it to work again for a little bit
sorry i thought u said u all ready checked that i wouldn't send u ripping apart your column if u did.</TD></TR></TABLE>
No problem... I'm looking for suggestions
Re: (eg8tuner)
Alright I check that tomorrow. so just check for valtage and when i try starting the car it should make a clicking noise?
Anybody else have anything else I should look into?
sounds like a loose conection on the battery but im sure if your smart enough to put in a b18b u prolly already check the conections. i had a problem with my main relay but when i turned the key i didnt get anything. but u should replace it anyways. i heard that blowing on the relay cools it down to make it work. heat it wat makes it crap out.
Re: (EG6 Love)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 Love »</TD></TR><TR><TD CLASS="quote">sounds like a loose conection on the battery but im sure if your smart enough to put in a b18b u prolly already check the conections. i had a problem with my main relay but when i turned the key i didnt get anything. but u should replace it anyways. i heard that blowing on the relay cools it down to make it work. heat it wat makes it crap out. </TD></TR></TABLE>
Yeah the conection to the battery is tight. I'll check on the relay. How much do they cost?
Re: (mike03,95civic)
I've been searching about main relays and it sounds like most people still have power to lights, clock, gauges... I don't. Could main relay cause loss of power to these things?
rokwilder1
33
06-28-2006 10:49 AM
