TPS sensor issue on a gsr?
Old Feb 25, 2008 | 03:15 PM
VTECth1s's Avatar
Default TPS sensor issue on a gsr?
My 98 gsr is completely bone stock. I just recently had an idle issue. When at normal operating temp, the car idle's fine, between 750-850 rpm. But when driving and coming to a complete stop in neutral. The idle will suddenly jump up to ~1800 and down to ~1000. It will do this for about a minute or two, of the idle jumping. Then after, the idle will go back to normal. I've already cleaned out the IACV, and this has been occuring, when driving for the first 10-15 minutes after start up.
There are no CEL's at all, and the car already had a full tune-up prior to this issue. So today, I opened the hood to inspect what the problem could be. And went straight to the TB area, I looked at the TPS thinking maybe it's the sensor or the wiring. And Bingo!, I slightly moved the TPS wiring and plug around, and the idle would act up. But If I moved the wiring or plug a certain way, the idle would't jump around. I'm thinking either the wiring or plug on the TPS could be frayed/bad, or the TPS sensor could be faulty. Then again if it's a faulty TPS sensor, there would be a CEL correct?
If it is a bad TPS sensor and I get it replaced. The new TPS sensor needs to be calibrated correct? If so, how would I calibrate it?
Anyone have such problem? Maybe redo the TPS wiring? Change the TPS plug or TPS sensor? Any ideas would help, Thanks!
Old Feb 25, 2008 | 03:35 PM
Blahblah718293's Avatar
Default Re: TPS sensor issue on a gsr? (VTECth1s)
if its disconnected it may throw a code, its possible it may not though
connectors are no prob to replace, same with tps. and no you dont need to calibrate the tps. just figure out which you need, the sensor or the connector. or just go to a junkyard and pick both off.
Old Feb 25, 2008 | 04:16 PM
VTECth1s's Avatar
Default Re: TPS sensor issue on a gsr? (Blahblah718293)
Thanks for the info.
This shiit is annoying though!
Old Feb 25, 2008 | 07:01 PM
emooheo's Avatar
that sucks. yes you willl have to calibrate the TPS. its pretty easy actually
Old Feb 25, 2008 | 08:05 PM
VTECth1s's Avatar
Default Re: (emooheo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emooheo &raquo;</TD></TR><TR><TD CLASS="quote">that sucks. yes you willl have to calibrate the TPS. its pretty easy actually</TD></TR></TABLE>
Please, explain the procedure.
Old Feb 27, 2008 | 11:10 PM
patrick4588's Avatar
after you put the new tps on, you will need to use an ohm meter and adjust the tps until the ohm meter reads .45v at closed throttle. its simple. i got a brand new omni tps if you are interested
Old Feb 28, 2008 | 07:29 AM
dc4_wHORE's Avatar
Soldering Iron Wizardry
Default Re: (patrick4588)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">after you put the new tps on, you will need to use an ohm meter and adjust the tps until the ohm meter reads .45v at closed throttle. its simple. i got a brand new omni tps if you are interested</TD></TR></TABLE>
exactly right, i replaced mine, and my car ran funny until i calibrated it.
Old Mar 13, 2008 | 04:49 AM
o VALTER o's Avatar
where do you stick the positive and negitive contacts to determine the ohms on the tps sensor?
Old Apr 13, 2008 | 10:56 AM
[ iLL ] iNt3GrA's Avatar
Modified by [ iLL ] iNt3GrA at 10:00 PM 4/14/2008
Old Apr 18, 2008 | 10:56 AM
zero-one's Avatar
Default Re: ([ iLL ] iNt3GrA)
i would also like to know where you stick the ohm meter lines to check the resistance. hey i had this problem too. my car would run like **** with half a throtlel, i was using an after market tps sensor. i switched it with an oem one and the problem went away. just find a oem sensor and it should fix it. i just need help calibrating it.
Old Nov 20, 2008 | 09:10 AM
sick_dc2's Avatar
WHERE DOO YOU STICK THE OHM MEETTER ATT????/ THE ECU?/ AND WAT PIN OUTS????
Old Nov 20, 2008 | 09:14 AM
neardon's Avatar
I'm a Jackass
NO NEED TO YELL!!!!!
One little stick on ground (metal) and and one little stick on the wires coming out of the tps sensor. Only 1 wire is going to send voltage.
Old Nov 20, 2008 | 09:16 AM
sick_dc2's Avatar
hahha sorry! i just found it alreadyy! hahah thanks!
B17DA-SON
Feb 5, 2010 09:23 PM
5thGeneration
Jan 3, 2008 01:49 PM
1weakSi
Nov 19, 2004 09:49 AM
b16a1civichb
Jun 4, 2003 04:24 PM
