Tranny Problem
Old Feb 25, 2008 | 02:56 PM
Fern413's Avatar
Default Tranny Problem
I have a 90 DA that is 5 speed and the problem is that everytime im crusing on the highway in fifth gear it pops outta gear a few times...but today on my way home it popped out 6 times until i decided to hold the shifter in fifth gear with out letting it go...and this time it didnt pop outta gear!!!!....wtf!!!...is going on has anyone ever expericed this problem before.....shifter also has a lot of free play to the point where it feels like neutral when it is in gear...can it be that my shifter bushings are completely worn or something in the shift linkage is loose??...
Modified by Fern413 at 6:41 PM 2/25/2008
Old Feb 25, 2008 | 02:58 PM
street_bliss's Avatar
most likely it is an internal problem inside the transmission. and it will be much cheaper to just buy another used one than to have someone rebuild it.
Old Feb 25, 2008 | 03:06 PM
Fern413's Avatar
Default Re: (street_bliss)
I checked the tranny and it looks like its leaking fluid....I have to check and see if im low on fluid or if im completely out....can that also cause this problem??
Old Feb 25, 2008 | 03:17 PM
Fern413's Avatar
Default Re: (Fern413)
bumpp
Old Feb 25, 2008 | 03:57 PM
Fern413's Avatar
bumpp...any1???
Old Feb 25, 2008 | 05:45 PM
Fern413's Avatar
bump...any info
Old Feb 26, 2008 | 11:25 AM
Fern413's Avatar
bump
Old Feb 28, 2008 | 03:17 PM
Fern413's Avatar
bumpp
Old Feb 28, 2008 | 04:49 PM
Fern413's Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">could also well be the engine or tranny mount</TD></TR></TABLE>
I have to change one of my mounts because i can feel the motor shift everytime i switch gears
Old Mar 2, 2008 | 01:45 PM
Fern413's Avatar
Problem solved....i drained out my tranny fluid and only about 1/2 a quart came out... tranny had close to nothing of fluid in there....so i changed the fluid and now no more 5th gear pop outs....
Old Jul 6, 2009 | 09:52 AM
mdhimes's Avatar
Default Re: Tranny Problem
Similar thing happened to me. I needed to fill it up with fluid.
The two main things that can cause shifter play is a bad or worn bitch pin and/or bad bushings.
Old Jul 6, 2009 | 10:12 AM
Mindgamez's Avatar
It sounds to me like your 5th gear syncro is going bad. Changing the fluid might help but wouldn't cause that to start happening. Since your fluid was low id be watching for other things now cause its never good to drive around with an empty tranny.
speedysohc
May 29, 2007 10:38 AM
2.3vtec
Sep 7, 2005 11:03 AM
nxstrikerxn
Mar 5, 2005 05:00 AM
integra pride
Oct 11, 2003 12:07 PM
