rpm activated vtec bad?
Old Feb 25, 2008 | 10:12 AM
civicjoe's Avatar
Default rpm activated vtec bad?
Hey guys I'm doing a y8 head swap on my D16y7 and I was wondering if using an rpm activated switch would be bad for the car. As far as I know when vtec is activated by a vtec ECU the computer switches over to the high-cam profile timing/fuel maps. Some people use an rpm activated switch to turn the vtec solinoid on/off, could this possibly damage the motor somehow?
I would think a setup with a vtec ecu would have more performance than just an rpm switch because the vtec ecu can switch to high cam maps and adjust timing and fuel according.
Versus the switch which will activate vtec and the non-vtec ecu will just see increased airflow and add more fuel and not switch to a different map so ignition timing would stay the same.
Am I right in this thinking?
Old Feb 25, 2008 | 10:26 AM
Relic1's Avatar
low cam maps and high cam maps are totally different.
tossing in a RPM switch for VTEC control may work to turn on the solenoid, but the car will run lean and have the wrong ignition mapping.
(NOTE: WOT the ECU does not use the O2 to determine how much fuel to push in, which means lean conditions at the worst possible time, which means melting parts)
Old Feb 25, 2008 | 10:30 AM
Padawan's Avatar
Darth ModerVader
Default Re: rpm activated vtec bad? (civicjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote"> I would think a setup with a vtec ecu would have more performance than just an rpm switch because the vtec ecu can switch to high cam maps and adjust timing and fuel according.</TD></TR></TABLE>
Yes, you are completely correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote">Versus the switch which will activate vtec and the non-vtec ecu will just see increased airflow and add more fuel and not switch to a different map so ignition timing would stay the same.</TD></TR></TABLE>
Actually, under WOT conditions, the ECU won't compensate for any additional airflow because it will be utilising the open-loop stored maps, which are not optimised for VTEC operation. Under partial-throttle conditions, the O2 sensor will be used to adjust the A/F mixture.
Old Feb 25, 2008 | 10:31 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">low cam maps and high cam maps are totally different.
(NOTE: WOT the ECU does not use the O2 to determine how much fuel to push in, which means lean conditions at the worst possible time, which means melting parts)</TD></TR></TABLE>
True, but it's just a D series. It wont melt parts. It just wont make power. I mean...it wont make power NA ever...but it will make even less power if you run it on the wrong map.
Basically, for example, since the HP change is 20hp from a Y7 to a Y8, you may only experience about 5hp or less of a gain with the RPM switch method since the fuel ratios and ignition timing is still for non vtec operation.
Go buy a manual Y8 ECU. Hopefully you have a manual Y8 manifold or a 92-95 D series manifold. Without that, you wont have the right ECU/IACV combo. (I'm assuming your car is manual.)
Old Feb 25, 2008 | 10:43 AM
Blk00EJ8's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">Go buy a manual Y8 ECU. Hopefully you have a manual Y8 manifold or a 92-95 D series manifold. Without that, you wont have the right ECU/IACV combo. (I'm assuming your car is manual.)</TD></TR></TABLE>
I agree. Getting a new ECU will solve all your worries and you won't have to worry about jerry-rigging something up.
[insert mindless plug here]
If you do go the route of the manual trans Y8 ECU, I have one for sale. Check my sig, it's the P2P listed. I can let it go pretty cheap. PM me if interested.
Old Feb 25, 2008 | 10:45 AM
B serious's Avatar
Default Re: Re: (Blk00EJ8)
hey wait a minute.....I have a manual Y8 OBD2B ECU as well. Buy from me. I'm better looking.
Old Feb 25, 2008 | 10:50 AM
Syndacate's Avatar
Default Re: rpm activated vtec bad? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, under WOT conditions, the ECU won't compensate for any additional airflow because it will be utilising the open-loop stored maps, which are not optimised for VTEC operation. Under partial-throttle conditions, the O2 sensor will be used to adjust the A/F mixture. </TD></TR></TABLE>
I could be completely wrong on this but I thought under partial throttle the ECU also read sensor readings from the MAP and/or IAT sensor(s) in unison with the reading from the O2 sensor to decide the optimal engagement point adjustment.
Old Feb 25, 2008 | 10:53 AM
B serious's Avatar
Default Re: rpm activated vtec bad? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
I could be completely wrong on this but I thought under partial throttle the ECU also read sensor readings from the MAP and/or IAT sensor(s) in unison with the reading from the O2 sensor to decide the optimal engagement point adjustment.</TD></TR></TABLE>
The engagement point doesn't really change. The RPM trigger is the same. It has to be at that trigger or greater.
For example, you could roll into the 4500rpm trigger with less than required throttle position. At that point, (at the risk of sounding cliche), the VTEC system would be "armed and ready". When the rest of the parameters are met, VTEC will actually operate.
However, if you sit at very low throttle position, but manage to rev the car to redline, VTEC will never operate.
All the parameters have to be met, but the trigger point never changes.
Old Feb 25, 2008 | 10:55 AM
Syndacate's Avatar
Default Re: rpm activated vtec bad? (B serious)
All the parameters have to be met, but the trigger point never changes.</TD></TR></TABLE>
I know, but the parameter requirements are only temperature, not in neutral, RPM, and a few other things. I'm pretty sure VTEC will still engage if you use a low throttle position to put your car to the redline, but it will engage later than the standard 4800 RPM that it would at WOT.
Old Feb 25, 2008 | 11:41 AM
B serious's Avatar
I know, but the parameter requirements are only temperature, not in neutral, RPM, and a few other things. I'm pretty sure VTEC will still engage if you use a low throttle position to put your car to the redline, but it will engage later than the standard 4800 RPM that it would at WOT. </TD></TR></TABLE>
Nope. You can roll into VTEC range and duck below the TPS limit. VTEC will not operate. IIRC, it's like 25% throttle or something.
Lets say that it's 25% throttle. If you get into VTEC RPM (let's say 4800) at like 26% throttle, it will operate at 4800. However, if you go to 7500 at 24% throttle, VTEC will never operate. It looks for all parameters at a certain RPM. If they are met by any RPM after trigger point, it will activate VTEC. If all of them are never met, VTEC will never activate.
Parameters:
Coolant at operating temp
TPS at or above certain position
VTEC hardware/software/wiring in good working order
oil press
RPM signal exists and is at or above trigger
Speed signal exists and is at or above around 15mph
Old Feb 25, 2008 | 12:06 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">Parameters:
oil press
Speed signal exists and is at or above around 15mph</TD></TR></TABLE>
and the CEL is not on.
(some OBD2 CELs will not prevent VTEC, but most will)
Old Feb 25, 2008 | 12:12 PM
B serious's Avatar
Default Re: rpm activated vtec bad? (Relic1)
(some OBD2 CELs will not prevent VTEC, but most will)</TD></TR></TABLE>
It depends on what the CEL is for. My B16A still has VTEC with a CEL on for a primary O2 sensor.
My friend's 97 EX's VTEC works with several CELs.
Honda is surprisingly liberal about their "limp mode" operation. If the CEL is for a major fuel sensor, that may fall under the "VTEC software/programming" category.
For example: MAP sensor codes, IAT codes, TPS codes.
Old Feb 25, 2008 | 12:25 PM
civicjoe's Avatar
I'm surprised at the attention this thread has gotten already thanks everyone! Just reading the tutorials I noticed some people used rpm switches in their vtec head swap and was wondering if that was effective. I guess it isn't.
I'm going to switch over to OBD1 and go with a P28 ECU. Turbo is in the works and I'm gonna shoot for a moderate goal of 180 whp on stock internals. I'm planning on learning to tune so I'm gonna start out with D-series cause they're a lot cheaper to blow up than B series.
Since I'm going with the P28 ECU I won't need the y8 manifold right?
I was thinking that the y7 manifold and IACV would work if I use a P28 ECU.
Old Feb 25, 2008 | 12:28 PM
B serious's Avatar
I'm going to switch over to OBD1 and go with a P28 ECU. Turbo is in the works and I'm gonna shoot for a moderate goal of 180 whp on stock internals. I'm planning on learning to tune so I'm gonna start out with D-series cause they're a lot cheaper than B series.
I was thinking that the y7 manifold and IACV would work.
The Y7 manifold and IACV will DEFINATELY not work with a P28. It will only work with an automatic P2P.
You need a 92-95 D manifold or 96+ Y8 manual manifold.
Old Feb 25, 2008 | 12:48 PM
civicjoe's Avatar
You need a 92-95 D manifold or 96+ Y8 manual manifold.</TD></TR></TABLE>
Alrighty, I should be able to find those. Do I need just the manifold or do I need the throttle body too? From what I've heard it's the ecu/IACV combo that has to work and on all my old cars the IACV was on the throttle body.
Just to be clear what is the difference between the y7 and y8 manifolds? I'd think they'd have the same MAP sensor, where's the difference?
oh and yes it's a manual of course. After I'm done with this I'm swapping out the tranny for one from an EX. I currently have a CX and AFAIK it has the highest gearing of the EK generation.
B serious, you know your stuff. Thought I'd ask you about something else. I saw somewhere that the P28 looks for a four wire O2 sensor, is that right?
Also, the P28 doesn't look for the second O2 or the knock sensor right?
Anything else I need to know?
Sorry if I'm asking a lot of questions, I've read all the how-to's and am quite acquainted with the search function
Old Feb 25, 2008 | 01:29 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote">oh and yes it's a manual of course. After I'm done with this I'm swapping out the tranny for one from an EX. I currently have a CX and AFAIK it has the highest gearing of the EK generation.</TD></TR></TABLE>
trans specs... http://hondaswap.com/reference...29132/
depends on if it's a hatch or coupe/sedan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I saw somewhere that the P28 looks for a four wire O2 sensor, is that right?</TD></TR></TABLE>
correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also, the P28 doesn't look for the second O2 or the knock sensor right?</TD></TR></TABLE>
correct, OBD1 does not use the secondary O2. The P30 and P72 are the two main OBD1 ECUs that have the knock sensor ability.
Old Feb 25, 2008 | 01:57 PM
civicjoe's Avatar
ya I've got the hatch... I think all CX civics are hatches
regal1975
13
Apr 13, 2007 06:00 PM
philkehn
10
Oct 3, 2006 11:55 AM
blkhatch92
Nov 29, 2005 11:04 AM
Imprezor
16
May 10, 2005 03:05 PM
eg6madness
Mar 5, 2003 07:52 AM
