wiring harness question
Old Feb 25, 2008 | 10:08 AM
advan414's Avatar
Default wiring harness question
I got a 94 obd1 b18 and a 96 obd2 ek hatch and i got a p28 obd1 ecu and i have the wiring conversion from obd2 to obd1. i was wondering what would be the easiest way to wire everything. i was thinking of buying a obd2 b18 wiring harness or should i buy a obd1 wiring harness.my freidn was saying even if i buy a obd1 harness id still have to do some wiring and do a mix between my stock obd2 hrness and the obd1 because the obd1 wont plug into the firewall i dont know what to do i really dont wanna be cutting and splicing wires together. and it would help if anyone could tell me what harnesses are compatible like b16 wiring harnesses with vtech or somethig thanks it will be alot of help.
Old Feb 25, 2008 | 10:13 AM
jax97hx's Avatar
Default Re: wiring harness question (advan_turbo_gsr)
You could use a obd2 engine harness but you will have a few unused connectors running a obd1 motor.
I think its best to ahve a custom harness when u do a swap of that sort but if not custom then the harness made for that motor would be best.
hope this helps
slambedcivic's Avatar
I know that the OBDIIA B series harness will plug right into an OBD1 car. However I dont know the other way around. Are you doing a LS or a GSR? whatever you run, just get the OBDIIA Ecu that corresponds with your swap.
Old Feb 25, 2008 | 10:17 AM
advan414's Avatar
im doin a b18c1 so a gsr.. if i get the obd2 harness it should plug int my firewall and i shouldnt have to cut and switch any plugs around would i?
Old Feb 25, 2008 | 10:19 AM
im pretty sure that you can plug your obd1 gsr harness right into the obd2 car. i know that i was able to plug my obd2 integra harness into my obd1 civic. but i dont know about obd1 integra to obd2 civic. wish i could help more.
Old Feb 25, 2008 | 10:21 AM
advan414's Avatar
Default Re: wiring harness question (jax97hx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax97hx &raquo;</TD></TR><TR><TD CLASS="quote">You could use a obd2 engine harness but you will have a few unused connectors running a obd1 motor.
hope this helps</TD></TR></TABLE>
well someone was tellin g me even if i use the stock one the mymotor (which would be a obd1 b18c1 wiring harness) that i would have to customize it cause the connecter from the engine to the ecu wouldnt work
Old Feb 25, 2008 | 10:44 AM
i dont have the answer for that, i am sorry
Old Feb 25, 2008 | 02:28 PM
lilo_goki's Avatar
just sell ur motor and get a 96 and up gsr motor so u can ref'd it.
advan414
Feb 24, 2008 04:41 PM
danxdan
Jul 13, 2005 03:37 PM
DGAF
Jul 7, 2005 05:37 AM
Cain Marko
Jul 7, 2004 02:40 PM
Erik_Pb_Foot
Oct 15, 2001 09:52 AM
