2000 civic si transmission problem
Old Feb 25, 2008 | 09:12 AM
99JdmDc2's Avatar
Default 2000 civic si transmission problem
The problem is a buddy of mine said my main bearing in the tranny was bad, but I didnt believe him cuz the tranny seemed fine but now when i am in like pretty much any of the gears and left off the gas so the car will deaccelerate the passenger side axle seems like its popping in or out, because I can feel it. Any suggestions of what it could be would help.
Old Feb 25, 2008 | 09:18 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 2000 civic si transmission problem (99JdmDc2)
Be more descript of the actual problem. Your description is way too vague right now.
Old Feb 25, 2008 | 09:31 AM
99JdmDc2's Avatar
well,I basically desribed whats going on. Say I am cruising in 3rd gear and I let off the gas but leave it in gear it feels like the passenger side axle is moving in and out.
Old Feb 25, 2008 | 09:56 AM
B serious's Avatar
Default Re: (99JdmDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99JdmDc2 &raquo;</TD></TR><TR><TD CLASS="quote">well,I basically desribed whats going on. Say I am cruising in 3rd gear and I let off the gas but leave it in gear it feels like the passenger side axle is moving in and out.</TD></TR></TABLE>
Try by checking the suspension components.
did you crash the car recently? launch it way too hard? Replace an axle? Dont leave out any details of past problems or situations.
When did it start happening? Why does it feel like the axle is popping out? Do you feel it in your steering wheel?
Cmon.
Old Feb 25, 2008 | 10:22 AM
99JdmDc2's Avatar
I have never crashed the car, never launched it once, but I cant say that the last owner didnt launch it nor replaced an axle and it just started happening not too long ago and yeh i can somewhat feel it in the steering wheel.
Old Feb 25, 2008 | 10:26 AM
B serious's Avatar
Check your suspension parts. Maybe something is broken or loose.
Check your axle.
Like I said before, you gotta get more info. It's impossible to E-fix someone's car with very little info. I understand that you only have a limited amount of info, but go jack up your car and look underneath. If you dont know what to look for or can't figure it out still, then go to a shop. Or take it to someone who knows what to look for.
Old Feb 25, 2008 | 11:03 AM
thisisntjared's Avatar
Default Re: (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">Like I said before, you gotta get more info. It's impossible to E-fix someone's car with very little info. I understand that you only have a limited amount of info, but go jack up your car and look underneath. If you dont know what to look for or can't figure it out still, then go to a shop. Or take it to someone who knows what to look for. </TD></TR></TABLE>i agree. do you know what it really feels like when an axle is popping out???? when an axle pops out the car will roll like its in neutral. is it a vibration from the passenger side? does it make any noise???
is there anything while you are accelerating? does the behavior change when you are turning in either direction.
Old Feb 25, 2008 | 10:23 PM
99JdmDc2's Avatar
yeh I had in axle in my integra pop out before so i know what its like,well I have work off tomorrow I am gonna pull it in the garage and have a look at it. Ill keep ya updated.
Old Feb 26, 2008 | 10:33 PM
99JdmDc2's Avatar
well i got underneath the car and discovered I am missing one of the motor mounts bolts. its the one that bolt the motor to the bracket, so i am gonna buy one and stick it in and see if that does trick.
Old Feb 27, 2008 | 07:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99JdmDc2 &raquo;</TD></TR><TR><TD CLASS="quote">well i got underneath the car and discovered I am missing one of the motor mounts bolts. its the one that bolt the motor to the bracket, so i am gonna buy one and stick it in and see if that does trick.</TD></TR></TABLE>... which mount? drivers side uppper, lower or rear?
if its the rear, this would be more characteristic of the problem. who did the motor swap??
Old Feb 28, 2008 | 09:53 AM
99JdmDc2's Avatar
its the rear mount. no its no swap its just the factory b16 motor, but i heard the owner before me broke a motor mount so I am going to guess it was the rear one based on the situation.
dc2[HI]
Aug 7, 2008 11:03 AM
chalupa
Aug 19, 2007 10:14 PM
Novtecdohc
Dec 15, 2005 09:09 PM
crazy eyez killa
Nov 26, 2003 05:57 PM
tyflip2
Nov 10, 2003 09:52 PM
