Test cooling and condensor fans
Old Feb 24, 2008 | 08:59 PM
deklao's Avatar
Default Test cooling and condensor fans
When I unplug the temperature sensor at the lower hose which control cooling fans, should both right and left fans (cooling and condenser) turn on or just only one on?
Old Feb 25, 2008 | 01:05 PM
deklao's Avatar
any tech guys here? It's simple to test. All you have to do is unplug the connection from the temp sensor next to thermostat. jump the wire. the fan should come on. I just need someone to verify for me as reference.
Old Feb 25, 2008 | 05:32 PM
Chiovnidca's Avatar
Default Re: (deklao)
They should both run.
Old Feb 25, 2008 | 08:08 PM
deklao's Avatar
thank you for responding. Mine only one fan runs. But both fans are ok. I tested them by connect directly to battery. Is there any relay between the fuse box and the fan itself?
Old Feb 25, 2008 | 08:40 PM
loup05's Avatar
on my cd5 i have a relay that mounts onto the condesor fan.. theres actualy 2 of them.. ones for the AC clutch and the other is for the condenser fan i think
big_jay239b16A
16
May 7, 2015 03:31 PM
BlackShingo
May 3, 2010 08:51 AM
toyonda
Dec 10, 2008 06:07 AM
lilo_goki
Dec 3, 2007 02:47 PM
90Accord-R
Oct 17, 2003 07:30 AM
