Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Civic LX fuel switch install
Old Feb 24, 2008 | 09:33 AM
Clairvoyant's Avatar
Default 2002 Civic LX fuel switch install
Hi Everyone. I'm looking at installing a fuel pump kill switch in my 2002 Civic LX 4-door. I've read up some about it, and I work in Electronics Engineering, so I have no problem doing it. However, I was wondering if there are any guides especially for this era of Civics, so I know how to properly get into the centre console, etc, without scratching up or breaking any of the plastic covering while I try to get in. I'm thinking of just taking off the cover on the centre console, (where the gear shift is), find the right wire, and then find a place to hide the switch. Any tips, info, pictures, are greatly appreciated! Thanks.
Old Feb 24, 2008 | 09:37 AM
toyomatt84's Avatar
Sanji
The Fuel Relay is mounted behind the hinge support beam holding the Glove Compartment.
Old Feb 24, 2008 | 09:46 AM
Default Re: (toyomatt84)
Are there any other relays nearby that may get mixed up with this one? Also, do you know what the pin-out is for this relay, so that I know what wires go where?
Old Feb 24, 2008 | 10:07 AM
Default Re: (Clairvoyant)
I had a look behind the glove comparment and I see a few relays. Is the fuel relay the blue one? Also, which wire do I need to put the switch in line with? There's a mess of wires there.
Old Feb 24, 2008 | 10:16 AM
toyomatt84's Avatar
Sanji
I don't know the pin numbers off the top of my head, but I think the fuel relay is opposite the blue one.
http://handaaccessories.com/civmaint01.html
You may want to pick yourself up a Helm's Service manual.
Old Feb 24, 2008 | 10:41 AM
Anyone else have some info on this? Thanks.
Old Feb 24, 2008 | 11:50 AM
I found a wiring diagram online from an actual service manual. I looked behind the glove compartment and found the relay and the correct wires, etc, so I'm going to give it a try! I've got a 16A switch, which I think will still be fine, seeing how the max current 18awg wire can handle is rated around 16A. Wish me luck!
Old Feb 24, 2008 | 12:42 PM
JohnnyClutch's Avatar
good luck
Old Feb 24, 2008 | 12:54 PM
Default Re: (JohnnyClutch)
Got it all hooked up and it's working exactly as it should!
Crazy Lady
Audio / Security / Video
Feb 4, 2008 01:00 PM
Mikes2000civicsi
Feb 2, 2008 03:59 PM
GR_DC2
May 27, 2004 10:51 PM
Lynx
May 16, 2002 05:17 PM
tjtruong
Mar 6, 2002 07:30 PM
