Installing Fuel cut off switch
Old Feb 2, 2008 | 05:25 AM
Crazy Lady's Avatar
Default Installing Fuel cut off switch
Ok I was reading the directions and i was wondering if there is another place I could put the switch, other than under the dash (cause that is real obvious) or the rear driver's panel (because everyone that reads this form knows that). I was thinking under the seat or in a different section of the panel. but every thing I think of there's something in the way of me doing it. Any sugestions?
Old Feb 2, 2008 | 08:39 AM
Crazy Lady's Avatar
Default WTF?
ok you guys read it but no sugestions? I was thinking about putting it in the ash tray so its convenient and hidden, does any of you know if the fuel wire routes near there? on a 96 Civic DX?
Old Feb 2, 2008 | 09:14 AM
fcm's Avatar
fcm
Old Fart
Default Re: Installing Fuel cut off switch (Crazy Lady)
That would be the coin tray not the ash tray, the PGM-FI Main Relay should be directly behind it.
Hint... instead of installing the switch on the fuel pumps power lead, install the switch on the PGM-FI Main Relays ground lead, [ground for fuel injectors relay coil] this is a low current ground, [ under 250mA] so a very small switch can be used, making it easier to hide.
cutting the ground to the PGM-FI Main Relay will cut power to the fuel injectors, the fuel pump, a number of sensors and the ECU/ECM. 94
Old Feb 2, 2008 | 01:44 PM
Crazy Lady's Avatar
Default Re: Installing Fuel cut off switch (fcm)
coin tray/ ash tray I dont use it, anyways won't
that trigger a code?
Old Feb 2, 2008 | 02:20 PM
94_DC4's Avatar
Doing the main relay kill will not trigger a code.
Old Feb 2, 2008 | 03:51 PM
B18C_EJ8's Avatar
Why don't you just advertise where you're putting your switch?
Also, why not put the switch in one of the blanks right above the coin tray? It'll be just as easy to find, and you won't have to go through all that trouble of opening the tray to start your car...
The whole point of a "well hidden" kill switch is to, well, hide it well...
Try another spot.
Old Feb 4, 2008 | 01:00 PM
96WhiteOnBlack's Avatar
Default Re: (B18C_EJ8)
A friend of mine with an EK Hatch bought his car with a fuel cut off switch on a panel in the back seat. Its just within his reach while hes sitting in the driver seat. You cant see it all unless you pull the seat up. Very inconspicuous! Good luck!
david76008
Audio / Security / Video
Apr 5, 2009 04:04 PM
Mr.Death
Jul 21, 2008 07:11 PM
socalrex88
Mar 2, 2008 01:50 PM
em1woot
14
Oct 24, 2007 09:53 AM
itsJDMyo
16
Jul 20, 2004 06:25 AM
