wont build all 8 pounds
Old Feb 23, 2008 | 05:33 PM
94c1v1cex's Avatar
Default wont build all 8 pounds
have a homemade kit that i put together with a hf manifold and a 14b turbo. when i first got the car tuned it would make all 8 pounds through all gears but first. now it builds 4 to 5 in second 5 in third and 7 in fourth. any ideas why it wont build the boost? on a full standalone tune system and the manifold and adapter plate is welded together. so it isnt a leak
Old Feb 23, 2008 | 10:33 PM
lsvtec300's Avatar
Default Re: wont build all 8 pounds (94c1v1cex)
do you have a boost controller or u run it of the westegate
Old Feb 24, 2008 | 12:16 PM
94c1v1cex's Avatar
Default Re: wont build all 8 pounds (lsvtec300)
boost controller... i can turn it all the way open and it still only builds the low boost... it isnt the controller because it worked before and the wastegate setting is 8 psi
Old Feb 24, 2008 | 05:14 PM
NVturbo's Avatar
O.G. triple O.G.
I'm guessing that you are using an internal wastegate mounted at the turbocharger...correct? You might want to check if the W/G flap is not messed up.
Old Feb 24, 2008 | 06:37 PM
lsvtec300's Avatar
if i was you i run it off the wastegate but keep in mine i don't know if you have a internal or external wastegate and see what ur boost is.if you still have the same problem then its ur wastegate
Modified by lsvtec300 at 10:08 PM 2/24/2008
Old Feb 24, 2008 | 06:45 PM
blinx9900's Avatar
could it be that the lil 14b is just dieing?? is it a junkyard turbo? any smoke from the turbo after hard passes?
Old Feb 28, 2008 | 08:13 AM
94c1v1cex's Avatar
Default Re: wont build all 8 pounds (blinx9900)
my first thought was the little bastard was dyin too... no smoke or anything... i am about to have sls make me a manifold for a big 16g or somethin and build the block i guess...
but to answer questions ya it is internally gated and to make sure the stock setting on the internal gate is 8 psi?
Old Mar 3, 2008 | 06:24 AM
94c1v1cex's Avatar
bump
Old Mar 3, 2008 | 07:21 AM
JACER63's Avatar
is your bov set too soft and leaking in boost? i had a similar prob like this and it was my bov set too soft? adjusted and viola back to 10lbs from a weak 5-6
also check your inlet air filter maybe starving the turbo inlet for air at boost..hope this helps
Old Mar 4, 2008 | 06:53 PM
94c1v1cex's Avatar
Default Re: wont build all 8 pounds (JACER63)
well i think it is too hard because the bov doesnt blow off unless i have at least 3 to 4 pounds built...
turbo_d
Jun 5, 2022 06:46 PM
pv2dickman
May 27, 2005 05:59 PM
Hoosier Daddy
Sep 6, 2003 06:44 PM
