new alarm system confusion
Old Feb 23, 2008 | 05:15 PM
HYBRIDCIVIC007's Avatar
Default new alarm system confusion
When im outside the vehicle the keyless remote unlocks passenger door. When im outside the car and put the key in the door it unlocks both doors. When i push the power door lock switch on either side it only unlocks both doors and locks the passenger door(not the drivers)? Its a 98 lude. Anyone have any ideas whats causing the driver door not to pop?
Old Feb 23, 2008 | 09:20 PM
Default Re: new alarm system confusion (HYBRIDCIVIC007)
whoa guys slow down on the replies, to much to read. hahahha come on someone has got to have some advice
Old Feb 24, 2008 | 07:14 AM
fcm's Avatar
fcm
Old Fart
Make and model of "new alarm" would help.
It could be a wiring problem with the "new alarm", [how it was wired to the OEM power door lock system] although it is a simple neg.(-) pulse system.
Who installed the alarm?
Because you have problems with the OEM power door lock switch, it could be a problem with the OEM "Multiplex Control Unit, or the way the alarm was wired to the OEM system.
Did the door locks work properly before the alarm was installed? 94
Old Feb 24, 2008 | 11:24 AM
Its an autopage rf-220 and the problem happened before the alarm was installed. Stereo usa plus or something like that in covina ca.
Old Feb 24, 2008 | 12:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: (HYBRIDCIVIC007)
If it happened before the alarm was installed then you will need to replace your "Multiplex Control Unit" found under pass. kick panel trim. 94
Old Feb 24, 2008 | 02:52 PM
so it wouldnt be just a solenoid or actuator? How much do those things cost etc?
Old Feb 25, 2008 | 05:25 AM
fcm's Avatar
fcm
Old Fart
If the door locks work in any direction it is not the actuators.
Honda/Acura power door locks are a " Ground At Rest Polarity Reversing" door lock system, that means both the leads going to the actuators are grounds when at rest, [not locking or unlocking] when you lock or unlock the doors the ground is "lifted" from one of the leads and 12V+ is supplied to it, the motor runs in one direction, to run in the other direction the ground is "lifted" from the other lead and 12V+ is supplied to it.
The switching, [lifting of the ground and the supplying of 12V+] is done by relays, there are two, [three if your car has "priority door unlock"] of them in the power door lock section of the Multiplex Control Unit, one for lock and one for unlock, it is a good bet that the contact points of the of one of the relays is bad, either a ground or the 12V+.
To test you will need a multimeter, or a test light that will test for both power and ground,
Sorry I do not have the colors of the actuator leads of a "98 lude" but they are probably white/red and yellow/red, both these leads should test as ground until you lock the doors, the white/red should go to 12V+ and the yellow/red should stay a ground, when you unlock the yellow/red should go to 12V+ and the white/red will stay a ground. 94
Old Feb 25, 2008 | 04:54 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRIDCIVIC007 &raquo;</TD></TR><TR><TD CLASS="quote">Its an autopage rf-220 and the problem happened before the alarm was installed. Stereo usa plus or something like that in covina ca.</TD></TR></TABLE>
off azuza blvd, ?
but to answer your ? I would go over what fcm said
Old Feb 26, 2008 | 07:38 PM
Well they are off arrow. Hmm i just need to find the cheapest and most simple solution. I slowly understood what he said but for me to test it all and to find out what to replace is another story. How far do you live from san gabriel valley area?
Old Feb 27, 2008 | 12:28 AM
30 mins
Old Feb 27, 2008 | 02:58 PM
Default Re: (wrx-killer-Sti-eater)
Ha ok how much will it cost me for you to fix my stupid non working locky
mickey513
Audio / Security / Video
Mar 12, 2014 03:10 PM
tobytigger
Aug 16, 2012 09:15 PM
jdm_is_ovrrated
Aug 31, 2010 01:04 PM
1984eghatch
Feb 16, 2010 05:36 AM
Hunter
Oct 27, 2002 08:02 PM
