Smoke coming from intake
Old Feb 23, 2008 | 01:03 PM
matmcg's Avatar
Default Smoke coming from intake
Car has trouble starting and when starts only stays on for a couple of secondz sthen smoke comes out of intake juhhh
Old Feb 23, 2008 | 01:47 PM
matmcg's Avatar
Default Re: Smoke coming from intake (matmcg)
bump
Old Feb 27, 2008 | 06:59 PM
matmcg's Avatar
bump
Old Feb 27, 2008 | 07:22 PM
97' Integra's Avatar
Probably need to repair or get a new distributor
Old Feb 27, 2008 | 07:34 PM
denraweb's Avatar
What happens when you give it gas after starting? Do you hear any "sucking" noises coming from where the intake is smoking? And is the smoke coming from the actual intake filter? Or from around the manifold?
Old Feb 27, 2008 | 07:38 PM
matmcg's Avatar
Default Re: Smoke coming from intake (denraweb)
yes i hear sucking but not a good kind sounds like it is choking and the smoke it coming out of the intake manifold i took off the filter and it poured out
Old Feb 27, 2008 | 11:26 PM
denraweb's Avatar
Well I would bet that you have something leaking inside or something is being sucked into the manifold...you need to remove the manifold, or at least look around the manifold and find out what it is...
Old Feb 27, 2008 | 11:33 PM
yc_dc4mar's Avatar
whats it smell like?
Old Feb 28, 2008 | 09:38 AM
matmcg's Avatar
smells like gas
Old Feb 28, 2008 | 10:18 AM
VTEC_PRODUCTION's Avatar
Default Re: (matmcg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">smells like gas</TD></TR></TABLE>
when was the last time you did a tune up?
Default Re: (VTEC_PRODUCTION)
oh and any cel? does it run rough?
Old Feb 28, 2008 | 10:55 AM
NAmodified's Avatar
check spark plugs and make sure the wires from the distributor are going to the right cylinders.
check cap rotor, spark plug wires, spark plugs, timing...
Old Feb 28, 2008 | 05:05 PM
matmcg's Avatar
I HAVE CEL 8 TDC SENSOR
Old Feb 28, 2008 | 06:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote"> I HAVE CEL 8 TDC SENSOR</TD></TR></TABLE>
there ya go. now fix it
Old Feb 28, 2008 | 06:21 PM
matmcg's Avatar
so basically new distributor?
Old Feb 28, 2008 | 06:40 PM
95dc2teg's Avatar
no the TDC sensor is located by your oil pump, i belive you have to take the crank shaft and timing belt covers off to get to it? (dont quote me) it might have come unplugged....
Old Feb 28, 2008 | 06:48 PM
matmcg's Avatar
i heard that is on obd2 cars but on obd1 cars it is in the dizzy
Old Feb 28, 2008 | 07:07 PM
95dc2teg's Avatar
ahh true, didnt realize you had an obd1 car.
Old Apr 7, 2008 | 02:50 PM
h23on17s's Avatar
Default Re: (95dc2teg)
yo im having the SAME problem. just rebuilt the motor... go to start it up and thats wat i get... wat did u finally end up doing?
Old Apr 8, 2008 | 10:27 AM
matmcg's Avatar
wrong distributor on the motor i changed to the right one and it worked
emotionisdead
Apr 9, 2008 02:42 PM
thunderboy
Feb 8, 2008 02:35 PM
thisisntjared
17
Oct 7, 2005 07:39 PM
wizzards581
Oct 24, 2003 06:41 AM
