ls/vtec ecu????
Old Feb 22, 2008 | 07:10 PM
wesley_925's Avatar
Default ls/vtec ecu????
apart from the cost$$$$. wats the best way to go with an ls/v setup. shud i use the p30. or will a chipped p28 do the same.
and can someone xplain wat the hondata s100 and s200 have in dif.
Old Feb 22, 2008 | 09:40 PM
advan414's Avatar
Default Re: ls/vtec ecu???? (wesley_925)
http://www.phearable.net hes good if oyu plan on turbo or any upgrade he will just send you a chip to the specs you want just pop out the old chip very easy he also sells s300 hondata stuff on the site just check it out for yourself.
Old Feb 22, 2008 | 10:48 PM
fmrprojects's Avatar
Default Re: ls/vtec ecu???? (advan_turbo_gsr)
whoever is gonna tune your car, get the software that they are use to tuning with. but for start up, run a shipped p28 ecu with a itr map abd you should be fine until you hit the dyno
dc4teg95
Engine Management and Tuning
Dec 21, 2010 06:17 PM
ls_bitik
Oct 22, 2007 08:52 PM
BoostdRex
Oct 30, 2005 10:11 PM
DarkTeg94
May 6, 2005 11:14 AM
Mr.DC2TurBo
Sep 15, 2004 12:46 PM
