Aftermarket Cam Gears....
Old Feb 22, 2008 | 05:15 PM
GSR_hatch936's Avatar
Default Aftermarket Cam Gears....
i got AEM cam gears for a b18c1 and im trying to set the timing and the marks on the sides dont match up its the two middle lines their off like a tooth..? is there a problem?? here's a pic..
Old Feb 22, 2008 | 07:23 PM
Default Re: Aftermarket Cam Gears.... (GSR_hatch936)
bumpity
Old Feb 22, 2008 | 07:42 PM
serio_ENDLESS's Avatar
it looks like the exhaust cam is a lil advanced i can really see if it is or not picis to small to tell
Old Feb 22, 2008 | 08:16 PM
Default Re: (serio_ENDLESS)
ok this is a bigger pic.!
Old Feb 22, 2008 | 08:44 PM
Pic too big?? bump...
Old Feb 22, 2008 | 11:14 PM
turbo-2nr's Avatar
not to be a *** but you do know you have to line the cams up manualy right? you dont just put them in ant there good
Old Feb 23, 2008 | 12:00 AM
Default Re: (turbo-2nr)
check this out man i got the cams like this when i bought the car and they where already set... I just replaced the head gasket and I tried to put it back on timing and the cam gears looked off...
Old Feb 23, 2008 | 07:36 AM
gourley's Avatar
Default Re: (GSR_hatch936)
It looks like the intake gear is a tad off
Old Feb 24, 2008 | 07:21 AM
Default Re: (gourley)
hrm.... The guy i got the car from said they where set a zero..???
Old Feb 24, 2008 | 01:11 PM
HeikDiesel's Avatar
The acutal degree of the gears is on zero but if you look the lines on the gears have to be parallel with the head. yours are off big time
Old Feb 24, 2008 | 02:50 PM
hatch96y7's Avatar
Default Re: (HeikDiesel)
how much of a difrence will this make perfomance wise beacause this is how my timing is and the distributor is way advanced and thats the only way it runs right
Old Feb 24, 2008 | 03:13 PM
94delsol6428's Avatar
Default Re: (hatch96y7)
Not completely sure what's going on, but since you don't have the belt on you can just turn the cams by hand. Make sure cyl. 1 is at TDC and then just align the markings on the gears. If your dist. is way advanced then I would retard it back to normal. The timing looks pretty messed up if this is the way that it was. You're motor not running right, or only running when your dist. is way advanced is a sign that your timing is way off.
Old Feb 24, 2008 | 03:21 PM
gourley's Avatar
Default Re: (94delsol6428)
Just put the stock cam gears back on. Aftermarket ones dont do anything unless you are going to adjust the timing for any reason. For DD, the stock cam gears work wonders and you will have the correct timing with them.
Old Feb 24, 2008 | 03:26 PM
egsleepercivic's Avatar
take off the belt, line everything back up then when you put the belt back on do it in this order, crank, tensioner , oil pum, exhuast cam,intake cam
gl
Old Mar 7, 2008 | 02:10 PM
Default Re: (egsleepercivic)
b16 cam gears work??? i got a pair of them? i dont got the gsr cam gears..
Old Mar 7, 2008 | 02:51 PM
gibsanez's Avatar
B16 cam gears should work
Old Mar 7, 2008 | 02:57 PM
t0u's Avatar
t0u
Pretty sick...
Old Mar 7, 2008 | 02:58 PM
t0u's Avatar
t0u
nice
lude98SH
Aug 9, 2007 11:51 AM
93b20z
Oct 11, 2006 07:28 PM
machine4321
Mar 29, 2005 03:44 PM
