Trans Fluid?
Old Feb 22, 2008 | 02:44 PM
Rittmeier89's Avatar
Default Trans Fluid?
Hello.
I have a 96 Accord EX (not VTEC) and Im going to change the tranny fluid.
Now im my manual it says to use honda's stuff and does not tell what viscosity to use. Would it be alright for me to use Synthetic 75w90 Gear Oil?
Thanks.
Old Feb 22, 2008 | 02:54 PM
95-Accord-EX's Avatar
Default Re: Trans Fluid? (Rittmeier89)
is it manual or auto?
pretty sure it should 10w30 tho. synthetic on trany=****
Old Feb 22, 2008 | 02:58 PM
Default Re: Trans Fluid? (95-Accord-EX)
Manual. I thought sythetic would be better? anyways can I use 75w90?
Im pretty sure its standard for most manual transmissions
Old Feb 22, 2008 | 04:24 PM
Would it be alright to use it for 3 months untill the next oil change and then shitch it to honda's formula?
Old Feb 22, 2008 | 06:21 PM
The-Kid's Avatar
Default Re: (Rittmeier89)
Sorry but this is off topic. How is your Accord EX if it doesn't have VTEC? From what I know, All the EX have VTEC....
Old Feb 22, 2008 | 07:29 PM
Off topic? What do you mean. Not all EX models are VTECs. There is 2 types of motors put into these models. There is the F22-B1 witch is the VTEC and the F22-B2 which is what I have. So does anyone know if I can use that gear oil in my tranny?
Old Feb 22, 2008 | 11:50 PM
i93SE's Avatar
the civic family line up ex in us is ex-r in Canada , i think same with accord
Old Feb 23, 2008 | 08:00 AM
TheMuffinMan's Avatar
He knows where you live!
Honda MTF
Don't use Synthetic, don't use random stuff.
Just use Honda MTF it's not expensive at all
Old Feb 23, 2008 | 10:07 AM
The-Kid's Avatar
Ahhhh nvm didn't see where you were from. Everyhting is like totally diff. than US. My bads. Over here, all EX models came with F22B1...
Old Feb 23, 2008 | 07:54 PM
someone else's Avatar
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rittmeier89 &raquo;</TD></TR><TR><TD CLASS="quote">Manual. I thought sythetic would be better? anyways can I use 75w90?</TD></TR></TABLE>
Do not put 90 weight in your tranny. It is far to thick.
I can never remember if it's 10w30 or 5w30 but you can use regular motor oil in place of Honda MTF.
90 weight/GL-5/or any standard gear lube will not work.
Old Feb 24, 2008 | 04:25 AM
Blamm!!'s Avatar
Default Re: Trans Fluid? (someone else)
dude ...do be puttin' 75W90 gear oil in your tranny!!!!!! unless of course you want to expletive it up. use motor oil if anything. -MTF is what your supposed to use.
Old Feb 24, 2008 | 06:45 AM
YeuEmMaiMai's Avatar
no for the states all ex models are vtec
in canada it is different
10W30 for manual trans or Honda MTF
Old Feb 25, 2008 | 02:56 PM
alright thanks I went and got some Honda MTF today.
Old Feb 25, 2008 | 03:25 PM
Fern413's Avatar
use 10W30
Old Feb 26, 2008 | 02:32 PM
SOHCMAN's Avatar
Default Re: Trans Fluid? (Fern413)
I have fund out that gear lube will WORK, but the shift action is so clunky you will change it right away... (Used 75w-90 mobil 1 gear lube)
The reason it doesnt work is it is the equivalent of putting a 20w-50 motor oil in there, just with tons of anti-shear additives for things like rear differentials. And 20w-50 is way too thick for a tranny designed with clearances suitable for a 10w30 oil. But Honda MTF is better than regular motor oil...
Live and learn
sohc
shane 271
25
Nov 15, 2018 10:21 AM
bdmlilburn
Aug 19, 2011 11:02 AM
zx2gotboost
39
Jan 4, 2006 04:01 PM
jagged4698
Nov 22, 2004 12:58 PM
Mlibby
18
Sep 1, 2004 05:43 AM
