CEL 22 LS?V in 94 civic
i have a 94 civic with a ls/V b18b bottom b16 topend. it has never worked well but vtec works for a day or two then it throws a CEL 22 and it goes out for days on end i check oil is good a lil over. what should i check should i replace the Vtec soiloid on the head or what is my plan of action. thanks
Make sure you have a good ground for the vtec oil pressure switch, and clean the screen/gasket where the valve body mounts to the head. See if this clears up anything and go from there. Good luck
could be a bad switch, like the other guy said check the screen.
Do you have a VTEC oil pump or are you still rocking the LS oil pump?
If so do you have an oil pressure gauge and what is you oil pressure in VTEC WOT?
4door hobo
Jul 30, 2007 07:53 PM
BeeResp0nsible
Nov 29, 2002 05:43 AM
