What to use to rotate rear brake piston?
AutoZone sells this little block tool that has little prongs sticking out and you put 3/8 ratchet in the other end. Its in the OEM section on isle 2.
yeah look for a "rear caliper wind-in tool" or something like that...using it is self explanatory
if you havent already, try to find a straight, flat piece of metal and put it inthere sideways to get more leverage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day »</TD></TR><TR><TD CLASS="quote">but what is the piston lol</TD></TR></TABLE>
The rear....brake....piston?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day »</TD></TR><TR><TD CLASS="quote">i'm a noob on suspension, but i'll find out</TD></TR></TABLE>
it's on the brake caliper, you CAN'T miss it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day »</TD></TR><TR><TD CLASS="quote">If its what I think it is then I'm sry for wastin everyones time, because I had to use a c clamp to get it to go down to get the pads back in.
Thanks</TD></TR></TABLE>
DO NOT use the c clamp on the rears unless you want to make them sieze up. Fronts you use the c clamp, Rears you have to rotate them clockwise.
ricekiller
16
Sep 19, 2004 08:14 AM
