Turbo interchange between Mitsubishi?
Do all mitsubishi stock turbos have the same bolt pattern/design? I currently have a td04h (GSX Turbo) and I was wondering if I can throw like an EVO turbo on there with no problem. If I am correct the evo has the same housing, correct me if I'm wrong. So can I just remove my old turbo and slap on the EVO one?
your best bet would be to run a 20g if you want it to 'bolt in' you could also look at FP turbo's again.. Bolt in turbos.
Goodluck.
Goodluck.
