Cant select any gears?!
Old Feb 21, 2008 | 09:08 AM
b16jaf's Avatar
Default Cant select any gears?!
I was driving home earlier and started slowing down as i came off the highway, only to find that i couldnt select 4th, or any other gear for that matter. by the time i had rolled to a stop i just about managed to select 2nd and it got me home, but every gearchange is like russian roulette now. its as if the clutch isnt fully disengaging but i havent had any problems with anything to do with the transmission until now, seems weird that this has happened so quickly?
Old Feb 21, 2008 | 09:10 AM
Probot's Avatar
Default Re: Cant select any gears?! (b16jaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16jaf &raquo;</TD></TR><TR><TD CLASS="quote">I was driving home earlier and started slowing down as i came off the highway, only to find that i couldnt select 4th, or any other gear for that matter. by the time i had rolled to a stop i just about managed to select 2nd and it got me home, but every gearchange is like russian roulette now . its as if the clutch isnt fully disengaging but i havent had any problems with anything to do with the transmission until now, seems weird that this has happened so quickly? </TD></TR></TABLE>
your trans is trying to shoot you?!!? nah jk, when was the last time you changed the tranny fluid?? and does the trans make any noise while idling or while you are in gear??
oh yea, what motor, trans etc are you running.??
Old Feb 21, 2008 | 09:34 AM
b16jaf's Avatar
sorry... its a SIR2, so a b16a and whatever box it should be i'm guessing. Fluid was changed about a year ago.
Old Feb 21, 2008 | 09:46 AM
Probot's Avatar
Default Re: (b16jaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16jaf &raquo;</TD></TR><TR><TD CLASS="quote">sorry... its a SIR2, so a b16a and whatever box it should be i'm guessing. Fluid was changed about a year ago.</TD></TR></TABLE>
id definitely start by putting new fluid in, im assuming the clutch is probably never been changed so that could be a possibility. does it grind alot or at all?
Old Feb 21, 2008 | 11:45 AM
Blk00EJ8's Avatar
Default Re:
It sounds like a clutch master or slave cylinder went out so the clutch isn't full disengaging. Check your clutch fluid reservoir to see if it's low and then check each respective cylinder for leaks.
You can get away with no clutch in shifting to gears 2-5 if your timing is good.
philkehn
Oct 27, 2006 06:58 AM
z51LS2
Apr 16, 2006 05:17 PM
Komptech
Mar 29, 2005 07:35 PM
Hebrew-Hammer
17
Mar 14, 2005 12:32 PM
.doeboyfresh.
Feb 20, 2005 10:20 AM
